Electric power steering questions...
Does anyone know what this pump setup is ?
![](http://www.jasonlepleymotorsport.co.uk/04dashb1.JPG)
![](http://www.jasonlepleymotorsport.co.uk/04dashb.JPG)
fancy it, but do not fancy the £1100 bill from prebfab
Corsa and pug 206's i heard have this fitted, does anyone know....
Yep thats a corsa setup.
If you want it to be speed sensitive still though you need an interface to chat to the ECU that controls it.
Or you can just put it on a switch if you just want it for manouvering around.
Im doing similar on one of my girlfriend's cars soon (a mini) with the corsa setup, she sadly suffers from a bit of athritis (diagnosed back when she was only 14
) and due to the wide wheels, small steering wheel, and fairly quick ratio rack it makes it very hardwork at low speeds
Can give you the number of a friend of ours who has recently put a similar converstion on a manta 400 massive improvements.....there are a couple of other lads up here running mk 2's with p.s. convertions....
Regards
Ian
Regards
Ian
I think that answers all your questions Ding....i'll dig out Dale's no. but i'd leave til after the weekend he's doing a rally this weekend...
Regards
Ian
Regards
Ian
Also look out for Puntos... Z4s... Micra's
All have Electric PAS.... or you could research the MINI (bmw one!!) it uses an electic pas pump and a std pas rack...
Alex
Alex
i know were i can get one these motors and id remove it with plugs and as much cable as possible
so do they need hard wiring into ecu for speed sensing or not? if not its a straight forward job really?
Originally Posted by markk
mine uses electro-hydraulic - but youve gotta have a power rack to begin with
Originally Posted by NUTS RuS
Originally Posted by Stuart.W
Which electric pump would you recommend for use with a sierra cosworth power rack?
There are 2 types the upright one is the easiest to fit and sort out all the fittings for
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Is the wiring 12 volts from the ignition direct to the pump (via a relay?) or to its own ecu (didn't know if they are variable pressure)?
No ECU necessary - Direct feed pump via relay & 30A fuse.
We normally put them on a seperate switch on the dash too - so its selectable on/off![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Some Clio's have a similar set up too
in your experience is it ok to run a power rack without the pump pumping?
Could you wire it up to a potentiometer and so slow the pump down?
Also, what do you use to mate the pump up to the rack? Is it a job for a hydraulics company as its pretty high pressure.. c 1000 psi.
Forgot to ask, is the upright pump found on both the Saxo and 106?
Okay to run a power rack with no power yes, the fluid just gets moved manually. As Rich says its a commonish idea in some forms of sport. Why do you feel you would need to slow it down ? Obviously its only pumping its hardest on full lock to lock turns - not something that happens a lot on the road
The upright one which looks about the size of a coke bottle with a motor underneath is found on some Saxo's and Clio's and we always use hydraulic hoses with proper crimped ends yes.
