RS Turbo ABS
Old 04-05-2005 | 05:20 PM
Bubs's Avatar
Bubs
Default RS Turbo ABS
Right folks, i wanna take the abs system outa ma erst an wana do it right. what master cylinder fits on to the erst brake servo?
Am i right in thinking that it will need four brake pipe outlets on the new master cylinder.
Cheers folks
Old 04-05-2005 | 05:33 PM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
We dont change the master cylinder.
Old 04-05-2005 | 06:38 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Just the Reservoir. Its the XR3i one, but Good Luck because Ford have just taken the part out of production!!
Old 04-05-2005 | 08:00 PM
white cab's Avatar
white cab
just make sure you have a brake bias to the rear wheels to adjust braking force and use three way connectors to split the two take offs from the master cylinder to feed each wheel. I would stick to the rs master cylinder as it has a 25mm piston so can supply more fluid than the 23mm standard one.
you can use the rs res just blank the abs feeds off.
JK12
33
26-04-2021 12:09 PM
RSBryden
06-09-2015 08:39 PM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
Quick Reply: RS Turbo ABS
