Help needed regarding engine oil light
Old May 2, 2005 | 08:00 PM
turbo.jon's Avatar
turbo.jon
Default Help needed regarding engine oil light
just had a full engine rebuild done and finally got round to starting it today so i pulled plug off dizzy and cranked it over a couple times to get oil light to go out but it wont go out so looks like oil pump not been primed propperly when was fitted
the light is meant to go out isnt it by just cranking it over????
as i dont no if it only goes out after its running???
not happy paid money to have all this done and not working
any ideas or have i got to take oil pump off
cheers
jon
Old May 2, 2005 | 08:59 PM
escortrsmatt's Avatar
escortrsmatt
the oil light on my turbo didnt go out for a second or 2 after the engine had fired and was running.
Old May 2, 2005 | 09:10 PM
phil4x4saph's Avatar
phil4x4saph
I wouldn't have thought there would be enough pressure to put the light out - just by cranking the engine.
Going to be an arse clenching moment waiting for it to go out when you start it!
Old May 2, 2005 | 09:12 PM
turbo.jon's Avatar
turbo.jon
will give it a go tomorow just thought u had to crank it over first to get pressure so dont no if it needed to be running
Old May 2, 2005 | 09:25 PM
DazC's Avatar
DazC
Mine went out on cranking but it took a while. About 20 - 30 seconds...
Old May 2, 2005 | 10:15 PM
davidreader5's Avatar
davidreader5
HI,
Take plug's out give it short crank overs, around 7,sec a few times and it should prime system, give the stater motor a rest between cranks,what motor is it.
DAVE R.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
Old ford
Jul 31, 2015 06:50 AM
