Aston martin Brembo Info needed from brake peeps,
Spanner monkey
Hi Guys,
A while ago a mate sorted this out for me, He only had the one,
Would you know of where to source one the same or at least the same model as i'd like to possibly use it on a project fiesta i'll be doing! Would you know of a ball park price at all? it is radial mount rather than conventional and the only code / number i can see on it is
1 A
20.8427.04.
It is 10 & 3/4" long ( longest point ) and is 5 & 3/4" wide, it's 4 pot and the brake pipe fitting is in the centre.
Thanks if you can shed some light.
Cheers, Gary.
1 A
20.8427.04.
Cheers, Gary.
Spanner monkey
MWF, cool, if you could please mate, if it helps, i know they are used with a 355mm disc on the Aston's!
Dave ( Twins ), I have already spoke to him, got the oil slick and rocket launcher!
Dunc, Won't be at the pod as i have a PJ on, has he got Aston ones too then?
I'm 99% sure its the front caliper off a DB9
I've got one at work i've been using for 'measurment purposes', should have a set going on my Gti-R soon
I could check those numbers for you on monday if you want?
I'll have a look at the one at work tomorrow and let you know
As for price, havent got a clue I suppose you could go to Aston and get completley shafted for one Or keep an eye on ebay or something like that.
Here you go:
The number on the caliper i've got is nearly the same.
1A
20.8427.03
I assume the 03 on the end is possibly the year of manafacture as the one you've got says 04
This one is definatly the front caliper from a DB9, its 280mm high, 150mm wide, and the gap in the body of the caliper where the pistons are is 65mm
1A
20.8427.03
Spanner monkey
Originally Posted by leesrs240
Gadget i think mark at grove has a set of them on his garage floor will look nice when fitted
according to the above info its of a DB9..i just wanted to fuly confirm that first..and where to go for parts..dont wanna go to aston dealers..
i have a pair of those calipers (or they look amazingly similar) but badged up as jag ones?? im also looking for Bells,rotors,pads and a mounting bracket to fit a 3 door cossie if anyone can help??
[QUOTE=maccavvy;4228249]basically the same and being the same is 2 different things though.i want the pad to fit straight in...also where would i find part numbers on a range rover /touareg..i dont have one of those handy.
The pad IS the same......
You have a few options here, all of these vehicles are fitted with a pad that will fit that caliper, you could use:-
Alfa Romeo 166 (Brembo Caliper)
Alfa Romeo GT Coupe (Brembo Caliper)
Alfa Romeo 159 (Brembo Caliper)
Alfa Romeo Brera (Brembo Caliper)
Alfa Romeo Spider (Brembo Caliper)
Citroen C8 (Brembo Caliper)
Peugeot 607 / 807 (Brembo Caliper)
Volvo S60 / V70 (Brembo Caliper)
Ford GT
Mitsubishi EVO 5, 6, 7, 8, 9, 10
Subaru Impreza (Brembo Caliper)
Volkswagen Touareg (Brembo Caliper)
Range Rover Sport (Brembo Caliper)
There are plenty of aftermarket companies selling this pad.
Ford GT
@ mattie .cheers dude..your right too..just got some top notch pads from a local motor spares for a 607.been sat on the shelf 4 months....£30 bargain..just need pad fitting kit now.
also what info would you need to find out about rear pads.my mate has them.and he is on the look for pads and bits
Hi there guys..
thought id update you..cheers to matttie for the info .it was invaluable
i got pads for a pug 607 and clips and pins from range rover,they were the cheapest.got custom brackets made up and got em fitted.
sat on the original 325mm disc.
any ideas what the same for the rears
Part number is 20.8429.03 1 A on the caliper ?????
jason_nike
18-08-2019 10:53 AM
Wilsfoci
15
30-03-2016 10:26 PM
Jack and the Beanstalk
09-08-2015 07:03 PM
