2wd servo and master cylinder
Double bubble
Why did you let the guy touch your car again if you suspected he was scamming you? Did you actually look at the master cylinder the first time? Did he show it to you? Could he have maybe sabotaged it when he did the work?
192.168.100.1 192.168.1.1 jpg to pdf
What what? 😂😂
Double bubble meaning I double posted it happens sometimes with a bad connection, how you came to the conclusion I meant what you thought is a mystery mate CSI adam 😂😂
My og post below
Default 2wd servo and master cylinderHi can the servo and master be used from a 4x4 saph on 2wd 3dr? servo and masters are extinct cant find any or are thier any other alternatives anybodies found?
Thanks
Scott
My og post below
Thanks
Scott
Hi you can use a 4x4 but the brake pipes are on the opposite side so you will have to re plum the pipes but apart from that there plug and play . The 4x4 bottle moves more to the flitch so it gets away from the down pipe witch is a win win .all the plugs are the same
smiley (21-09-2020)
Cheers for that pal 👌
Simmo
28-11-2006 12:19 AM
