s2 gearbox number?
s2 gearbox number?
hi, just looked on my rst s2, and checking what is says on the bellhousing its says on mine v11. but my mate had a turbo gearbox out the other day and it says v11.2 on it,
have i got a 3i box in mine?, its a 88 spec
The bellhousing should say 87TT
To test if you have an LSD, jack both front wheels off the ground. Rotate one and the opposite side should rotate the same way. If it goes the other way its a normal diff.
hope that helps
hope that helps
rsguy
44
29-09-2015 03:29 PM
