Anyone tried a Garrett G Series on a YB yet ?
Old 02-11-2019, 01:52 PM
  #41
cossie51
cossie51's Avatar
The car drove great with very little lag and a good spread of power across the Rev range.
Run for 8 months and about 1800 miles and the turbo has loads of play in it and was starting to blow oil through with the boost which collected in the plenum cover hence why it's now gone back for a bigger turbo that will not be working flat out to make the same if not more power.
jsa (03-11-2019)
Old 02-11-2019, 07:05 PM
  #42
Rsmat
300+
Rsmat's Avatar
I'm running a GTX2867R gen 2 on a CVh , makes a T series turbo look crap .
Old 02-11-2019, 09:50 PM
  #43
cossie51
cossie51's Avatar
Not surprised as it's 3 generations in updates on from the T series turbos. I've bought the New G25-660 so will be a massive improvement over the T34.
Old 02-11-2019, 09:56 PM
  #44
james kiely
james kiely's Avatar
do these new gen garret turbos bolt straight onto a 2wd manifold?
Old 03-11-2019, 12:33 AM
  #45
Rsmat
300+
Rsmat's Avatar
Yea t3 flange mate
Old 25-05-2021, 06:49 AM
  #46
cossie51
cossie51's Avatar
Finally got round to getting my cossie mapped on the G25-660. I wasn't looking to make big numbers, just the best drivability I could get and most importantly reliability. I'm very happy with how it drives now and wouldn't want any more power on the road as the rear wheels struggle for grip now.
Old 25-05-2021, 08:30 PM
  #47
scoooby slayer
scoooby slayer's Avatar
Did they do an overlay plot of the t34 and the g series to see any gains/losses ?
Old 25-05-2021, 08:50 PM
  #48
Adam-M
Adam-M's Avatar
Seems to build boost quite late
Old 25-05-2021, 09:23 PM
  #49
markk
markk's Avatar
Looks too big of a turbo for the power its running. Lost a good chunk at the bottom and not taken the gains at the top.
Old 25-05-2021, 09:57 PM
  #50
scoooby slayer
Your right mate lost 500 rpm of spool and the g series runs 3 psi more boost, seems a step backwards ?
Old 25-05-2021, 10:03 PM
  #51
markk
markk's Avatar
Just looks like a classic case of mismatch on turbo for use. A 550 would have been much better I feel.
Old 26-05-2021, 05:55 AM
  #52
cossie51
cossie51's Avatar
a 550 only seems to make only 500hp and not 550 as named and I didn't want to be running it close to its limit so opted for the 660.
The car drives great and I haven't felt it's laggy at all. Plus a 660 gives me scope for more power in the future once i get use to it and it feels slow again.
Old 31-05-2021, 07:40 PM
  #53
scoooby slayer
Theres a guy on gtr owners who's fitted an ams turbo kit with the g35 1050 turbos it's not performed as expected and is now getting swapped out for a boostlogic kit instead
Seems the g30 900s have some positive feedback though
Old 31-05-2021, 10:13 PM
  #54
dan le moignan
dan le moignan's Avatar
How did this compare to the EFR 7064 in the end?
Old 01-06-2021, 07:35 AM
  #55
testastretta999
testastretta999's Avatar
The graphs I have seen on the g series gtr’s don’t look impressive, no better than efr’s which are probably older than 10 yrs now.
Some people say they do one good pull then have issues, I’ve not seen it first hand but I’m sure John Morgan posted on it.
Old 02-06-2021, 06:51 PM
  #56
Rsmat
300+
Rsmat's Avatar
Apart from the T34 comes in sooner than the 660 on the YB . By the looks of it .
Old 02-06-2021, 07:33 PM
  #57
scoooby slayer
Yeah looks to have lost 500 rpm of spool, has gained 25 hp but is running an extra 3 psi of boost above what the t34 was running, so realistically if it was at the same 23 psi likely be around 425 hp imo
Rsmat (02-06-2021)
Old 02-06-2021, 07:36 PM
  #58
scoooby slayer
I'd like to see twin efr 9180s on a gtr results but don't think anyone has done it
Old 04-06-2021, 06:06 AM
  #59
cossie51
cossie51's Avatar
The only issue is the T34 was running on its limit meaning it got extremely hot and so only lasted 6 months hence needing to go bigger on the turbo.
When driving it now I find It picks up low down much better than the T34 ever did, maybe it's due to the massive reduction in heat and the car in low boost on the G25 pulls harder and is much quicker and nicer to drive than it ever was on high boost on the T34.
It's massively improved how well the car drives which was the point for me. It's a road car and should be safe and reliable so I can actually use it rather than it sitting in the garage broken.
Old 04-06-2021, 08:23 AM
  #60
Rsmat
300+
Rsmat's Avatar
Never knew 23psi was on the limit of a T34 ..mine had 37psi and loved it
Main thing is your happy with it and its more drivable.. enjoy.
Old 04-06-2021, 09:13 PM
  #61
cossie51
cossie51's Avatar
same volume of air through a small hole will create much higher pressure than pushing it through a large hole.
It made 32psi before replacing with the following, top feed intercooler, 70mm DBW Throttle bodie and Hart plenum. After that anything over 23psi increased heat and power dropped
Old 04-06-2021, 11:29 PM
  #62
Rsmat
300+
Rsmat's Avatar
Ah the old measure of restriction .
I'm quite shocked to hear at 23psi it got too hot and power would drop as I've never seen a T34 on a YB do that before .
Old 05-06-2021, 09:42 AM
  #63
scoooby slayer
If it's making boost lower down the rpm range now when out on the road then the t34 must of been dynoed under a higher load than the new g30 turbo was, Dyno results are only comparable when equal load is applied for each run otherwise there meaningless
I've seen this with rods old Dyno runs, engine Dyno high load made boost 4000 rpm, but on the rollers it didn't make boost til after 5000 rpm due to the rollers applying less load on the engine
It also made 838 hp on the engine dyno but only 809 hp on the rollers
Old 06-06-2021, 06:29 AM
  #64
cossie51
cossie51's Avatar
For me, knowing what the power and torque figures are for the car is great but also totally irrelevant as it was all about how it drives on the road.
Yes I have lost a few rpm before hitting full boost but it pulls much stronger when building up to it than with the T34
on paper I've gained about 40 lbft and 25 bhp which after the stress and cost of it all, was very disappointing but when I drove the car even in its low setting of 18psi it's so much nicer to drive and despite the numbers on the dyno sheets it feels like I've gained a massive amount more power and torque so is a little bit confusing as the numbers and the way it drives don't agree in my brain.
The mapper was a little confused as he said the same turbo on something like a evo would be up around the 550 bhp and similar torque at the same boost levels
Old 06-06-2021, 08:07 AM
  #65
stevieturbo
C**t
stevieturbo's Avatar
Every engine is different, heads, cams, manifolds, efficiency, compression, fuel, etc etc
If it feels better in the real world, it's a result.
Dicko&Vacant
30-04-2007 09:38 PM
SPADGE
13
27-11-2005 07:05 PM
Disabled Account
25
06-06-2005 08:35 PM
Quick Reply: Anyone tried a Garrett G Series on a YB yet ?
