battery or something else?
Old Jul 7, 2019 | 03:28 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default battery or something else?
in the mondeo (mk3 2.0 petrol auto)
the battery in the car is showing 12.3v with everything off
not enough to start
give it a jump and it starts on the button, then it's showing 14.19v and with a little bit of throttle it's showing 14.26v
the fiesta i jumped it with is showing 14.46v when running
is this a small enough issue to make you think it's not the battery?
the replacement unused battery is showing 12.56v sitting on the shelf
Old Jul 8, 2019 | 05:32 PM
stevieturbo's Avatar
stevieturbo
C**t
What is the voltage during cranking ?
Sitting unloaded means little under the circumstance.
Old Jul 9, 2019 | 12:56 PM
martysmartie's Avatar
martysmartie
The voltage you have is fine (running).
It's exactly as Steve has said, you can not test a battery using a multi meter as all it will tell you is the voltage present at that point (no load).
You need to perform a drop test to test it, but yes the fact it starts from another power source would indicate the battery is faulty.
Martin
Nath
Dec 1, 2005 11:49 PM
SPADGE
37
Sep 17, 2005 08:20 AM
turbo.jon
Jun 8, 2005 05:28 PM
James Raby
Nov 5, 2004 02:36 PM
zvhturbo
Jul 19, 2004 02:31 PM
