Base map for Zetec Turbo (ignition map in particular) Megaquirt
Hi all, the time has finally come to get the car with some sort of map on it! Does anyone happen to have a base ignition map for a Zetec Turbo running Megasquirt? Just need some base figures to get it running
Thank you for any help
Engine Machinist
make sure you check the timing with a light before attempting to start it. there is a setting in there which uses static timing so that you can check it properly. There are a few ignition maps floating around on here, i just took a rough average of them for mine. There are a few good guides on youtube for how to set everything up for initial startup.
Si B
24-11-2012 08:15 PM
ASHCOSSIE
02-12-2007 08:11 AM
Ex-Finesse
07-04-2006 11:18 AM
