EFR Manifold wot you think
#81
#82
#83
For physical access to nuts and bolts...the last manifold I'd use is the standard 2wd one ! lol
#85
Cheers Paul
#86
this is efr7064 on stock 2wd manifold with different trouser section
https://www.youtube.com/watch?v=q3PfyeLALPM
#90
Does anyone know what sort of boost is run on 7064 for around 450hp?
My head gasket was replaced in 1998 (only done about 10k since) by castle performance for a group n head gasket what ever that is?!
Hope it will be ok with more pressure, holds 27psi no issues at the moment
#92
#93
Ok cool, I think it peaks just over 30 psi at the mo then holds 27.
think block needs decking for wrc metal gasket?
will see how I get on with the current one
#94
Guys does anyone know where to get studs for the efr manifold?
They are M10X1.25, common pitch seems to be 1.5 so struggling to find the 1.25 pitch with aerotight nuts etc
#97
Have ordered some carbon steel ones now, still struggled though in M10, could only find tri lock nuts in this pitch so hopefully they will hold tight
#98
Location: it's not where you are, it's where you've been and where you hope to be
get the genuine Mitsi Evo studs and nuts which are the correct thread - about Ł50 for 4 studs and nuts but the nuts don't come loose and they are re-useable
timsrs
84
31-03-2019 09:55 AM
ANDY XR2
19-10-2005 03:58 PM
ANDY XR2
19-10-2005 12:32 PM
SPEED FREEK RICH
17-10-2004 06:11 PM
