Cossie crank sensor.
Originally Posted by SECS
Its easy, just take your time.
Dont pull on the wires to unplug the original sensor. Hold it by the connector
otherwise you will break the loom or make it intermittent.
Not that I would be that stupid
unless lets say I was very hungover at some really early time on a sturday morning Trending Topics
arrrr i see
so could this be the reason for my car's current issues then
https://passionford.com/forum/viewtopic.php?t=113877
Dumb question now! Have located the sensor - what is the gap that needs to be set?
Is it the gap between the sensor and the lobes on the crank pulley?
The gap on this one is more like 8mm than 0.8
Am I just being a plank?
yes Phil, the gap between the sensor end face and the surface of the 4 target pegs on the pulley. (check on all 4 because they are likely to be slightly different, set the sensor position to 0.8mm max )
Thanks Rich!
Seriously though - you could get your hand between the sensor and the pulley!
Having looked at it - I think the oil dripping off it cant be helping either
Russ Payne
Sep 25, 2015 08:29 PM
