how to remove focus drive shaft from hub.
Hi I'm new to this but can anyone help?
I need to change front wheel hub and bearing. I have dismantled everything but can't get to drive shsft out of the hub, it's stuck solid.
Anyone had this problem before?
Thanks
Thanks
Loosen it all off, leave the drive shaft nut on about half a dozen turns, and give it a couple of good firm blows with a copper hammer, should come out.
Done up to a ridiculous torque so will be f-tight
Make sure you put a new nut on when you put it back together
If it's a mk1 Focus or any other Ford with 4 stud wheels then use a cheap hub puller, about Ł10
If it's a mk2 or any other with 5 studs then the hub pullers are a bit more expensive
Attach to the hub with a couple of wheel bolts and wind down the screw, easy, best though to use a couple of scrap wheel bolts
ffoc.co.uk
Here's how:
skypeller
10-05-2015 05:36 AM
spiker
18-04-2013 08:58 PM
