2wd diffs
Old Mar 13, 2018 | 12:20 PM
cossieboy599's Avatar
cossieboy599
Default 2wd diffs
Hi what' the best rear diff for a 600bhp 2wd saph ???
Old Mar 13, 2018 | 12:40 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Supra jag ford 9 inch take your pick
Old Mar 13, 2018 | 10:36 PM
cossynut2's Avatar
cossynut2
10 Year Member
With that much power on a 2wd Saff you are going to need something pretty strong!! What gearbox are you going to use ? If you live in Southampton Richard at Tremona Garage may be worth talking to.
Old Mar 21, 2018 | 05:52 PM
c20tbo's Avatar
c20tbo
Depends what its going to be used for really
Old Mar 21, 2018 | 05:54 PM
ajamesc's Avatar
ajamesc
If it’s got torque like the power and grip just hard acceleration with strip the teeth off a 7.5 cwp
Old Mar 21, 2018 | 05:59 PM
Caddyshack's Avatar
Caddyshack
If you are having to fabricate to add a different diff then worth considering a 6 degree in there at same time and have it made / make it to take the new diff as they hook up and handle much better on them.
Old Mar 21, 2018 | 06:16 PM
james kiely's Avatar
james kiely
I have the jag diff for my big bhp 3dr track car.I know from Rods car that they will take the power but how do they make the car handle on track ?
Anyone got one fitted that could advise please
Old Mar 21, 2018 | 06:37 PM
Caddyshack's Avatar
Caddyshack
I suspect that boils down to how the lsd is set up as I expect the weight isn’t hugely more?
Old Mar 21, 2018 | 07:09 PM
james kiely
its the standard jag powerlock toby ,so no real idea mate tbh
Old Mar 21, 2018 | 07:10 PM
Caddyshack's Avatar
Caddyshack
I don’t know enough about them but doubt it’d be too aggressive if jag road car spec
Old Mar 21, 2018 | 07:15 PM
james kiely
my mk 6 degree beam is made to suit ,so it will have to do for the minute .i know early 3dr rally cars ran them but god knows how they were setup
Old Mar 22, 2018 | 06:41 PM
Mark V8's Avatar
Mark V8
Jag diff has got to be twice the weight of a Cossie one, it's a real ball buster to lift.
I've got one fitted, but the car is a long way from being driven so can't comment on handling.
Old Mar 22, 2018 | 07:06 PM
Caddyshack's Avatar
Caddyshack
That’s a lot of weight out on a pendulum then....the supra diff is a chunky unit but I don’t think that much
Old Mar 22, 2018 | 08:16 PM
Adam-M's Avatar
Adam-M
It’s low down weight and at the rear so will more than likely balance the car out against the heavy engine so I wouldn’t be worried about it until it came to actually man handling the bugger on and off lol
Old Mar 22, 2018 | 09:32 PM
james kiely
i dont mind a few kilos mark ,if it dont break lol
Old Mar 23, 2018 | 08:59 AM
nixon_2wd's Avatar
nixon_2wd
Nice thing about supra diffs is that theres lots of parts and different lsds available for them. And they are very strong.
Old Mar 23, 2018 | 04:14 PM
stevieturbo's Avatar
stevieturbo
C**t
And people make fitting kits to bolt them straight in.
Lots of positives there.
Another option although it'd need DIY....what about the Nissan R200's or R230's ?
Again being a popular drift car item....lots of diffs and parts available ?
Old Mar 24, 2018 | 08:31 AM
turbotrev's Avatar
turbotrev
I wouldn’t necessarily says sierras hook up better on 6 degree beams tbh, I’d say they are more for handling purposes
Cheers Paul
Old Mar 24, 2018 | 09:21 AM
Caddyshack's Avatar
Caddyshack
Cheers Paul
Mine cured the wheel spin on mine. I believe that a lot of sierras dipped on the rear under launch and that dip caused the geometry to change which reduced grip. Part of the handling improvement is grip /traction in my understanding but I may be wrong.
Mark Shead and the chap who helped set my car up commented that it did mini wheelies under hard power, that almost went with the beam change.
Can’t wait to try full cradle and proper WRC shockers on mine.
Old Mar 24, 2018 | 12:55 PM
turbotrev's Avatar
turbotrev
Your right in saying the camber changes on the rear as the car accelerates and that can cause traction issues.
But I don’t think they are needed seeing as a lot of the quickest sierras that I’ve seen (in straight line acceleration) only have standard beams fitted...
There are other things you can do that cost no where near as much
Cheers Paul
Old Mar 24, 2018 | 12:59 PM
Adam-M's Avatar
Adam-M
Just by shimming the rear hub you can cure most of the wheel spin but I think the 6 degree beam will help against understeer
abdr500
Feb 19, 2006 08:53 PM
Christian and Beccy
Nov 7, 2005 11:11 AM
jim jones
Aug 14, 2005 04:19 PM
BAZZA BOY
May 7, 2005 03:53 PM
