aluminum radiator mk5 escort
Not sure if there is anything available off the shelf. Cheap solution if you want something slightly bigger is to use the rad of an Escort with air con, as I think these are a bit wider.
I'm sure someone would make you something. Mat at MDA Motorsport might be able to do you an F2/Maxi style one perhaps.
McGoo 69
Apr 29, 2015 05:28 AM
Richardpaulh
May 18, 2011 01:28 PM
ford-escort-rs-turbo
Jan 20, 2010 09:39 AM
