Difference between -31 and -34
Old Apr 11, 2005 | 03:06 PM
Rhys's Avatar
Rhys
Default Difference between -31 and -34
Right i got a -31 on my motor which is on its last legs Im going to get another one as per insructions of Mark But i forgot to ask what the differences is between the both?
So any idea? Yesterday i think it was told one comes in with more of a bang?
Old Apr 11, 2005 | 03:11 PM
Adam Ash's Avatar
Adam Ash
Old Apr 11, 2005 | 03:12 PM
Daveyboy's Avatar
Daveyboy
You can fine tune one of them more than the other
Old Apr 11, 2005 | 03:13 PM
Graceland's Avatar
Graceland
Team HOTHOT!
which one as i need a new one - the actuator thats on mine is something stupidly
Old Apr 11, 2005 | 03:15 PM
Daveyboy's Avatar
Daveyboy
-31 i think
Old Apr 11, 2005 | 03:16 PM
Rhys's Avatar
Rhys
Well Graceland i presume a -31 is better as thats what i been told to get But just wondering where a -34 would be better as obviously there must have been a need to produce it?
gurnE's Avatar
gurnE
Base lift pressure is alot higher on the -34 (14psi compared to 7psi from memory, which could be wrong)
You're T34, greys & 30psi aren't you Rhys?
I was told -34 is worthwhile on anything stage 3 or over
Old Apr 11, 2005 | 03:17 PM
spring ratings
10psi to 14psi i think....could be 14psi to 18 psi tho LOL....can't remember off top of my head.
T34 -34 is required IMHO makes it nice
Old Apr 11, 2005 | 03:18 PM
Rhys's Avatar
Rhys
GurnE supposed to be running over 30psi but currently car is only going to 25
Well Mark said -31 even for the boost so im getting one of those, as he knows what to do with the engine. Maybe its down as said above u can fine tune it more?
Old Apr 11, 2005 | 03:21 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Just to contradict Dingly, go for the -31, as combined with the correct jets in the amal valve and boost map in the chip, it does exactly what you want it to . Just listen to your tuner .
Old Apr 11, 2005 | 03:22 PM
gurnE's Avatar
gurnE
Well, I'd always say follow the advice of your tuner.
I went from a -31 to a -34 but also went to greys,T34 and boost controller all @ the same time so couldn't tell you if the actuator alone made any difference
Rhys's Avatar
Rhys
I am But just wanted to know the difference
Old Apr 11, 2005 | 03:24 PM
Surely you listen to the people that make the turbo
mine had a -34 when harvey did it, so did jay's and my tuner says -34 so
Old Apr 11, 2005 | 04:03 PM
morto's Avatar
morto
i have - 34 as recomended by stu but dont forget guys the main diff is lift off -34 needs 14 psi before lift will start and kicks you in the backside.. - 31 lifts at 7 and does the job smoothly dont also forget .. no amal valve means -34 with amal valve its up to you..
andzz
Old Apr 11, 2005 | 04:11 PM
CraigN's Avatar
CraigN
i also have a -34
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
little bram
Sep 27, 2015 07:45 AM
