Rs Turbo CVH crankshaft bearings
Old 30-07-2017 | 09:56 PM
Rsmat's Avatar
Rsmat
Default Rs Turbo CVH crankshaft bearings
What's best make to use and where is best to buy them from .
Many thanks Mat.
Old 31-07-2017 | 06:13 AM
haz87's Avatar
haz87
ACL(Heavy Duty) or Glyco
Rsmat (31-07-2017)
Old 31-07-2017 | 08:46 AM
Rsmat's Avatar
Rsmat
Thanks mate ..anyone know what kings are like ?
Old 31-07-2017 | 09:04 AM
haz87's Avatar
haz87
I've used them with no problem. On 2 CVH builds in fact so certainly one to add to the list. Just be aware King make many "versions" from cheap OE through to "race" spec etc so just double check you're happy with what you're buying
Rsmat (31-07-2017)
Old 31-07-2017 | 05:36 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I always use ACL and have not had an issues.
Old 31-07-2017 | 06:13 PM
jonfoc's Avatar
jonfoc
Never built an engine myself but all engines I've had built used ACL mate
Rsmat (31-07-2017)
Old 31-07-2017 | 06:20 PM
Rsmat's Avatar
Rsmat
Thanks lads ..think I'll look deep into the Kings if no good ill go ACL
Old 06-08-2017 | 01:45 PM
Dubs44's Avatar
Dubs44
something to bare in mind is some of the rs turbo blocks have 0.4mm oversize main bearing housings due to a manufacturing balls up at fords, should have it stamped on the back of the old bearings if you have them still, if not its best to get the housings measured just to be on the safe side
Rsmat (06-08-2017)
Old 06-08-2017 | 05:01 PM
Rsmat's Avatar
Rsmat
Yea it's all measured up ..just wanting to purchase the best bearings for the job mate .
