3.6 or 3.9 CWP ?
3.6 or 3.9 CWP ?
Dropping my 2WD diff off in the morning to have a Quaife ATB installed as the standard one broke the planet gears.
Do you notice much difference in acceleration if you change to 3.9 CWP ? As this would be the ideal time to have it changed.
Mark what are the options for front diff on a 4x4 running 3.9 in the rear i remember you said quaffe what power are these rated to? and if under 700 is thier an option beyond that?
smiley (15-07-2017)
Bara built me a 3.9 thick wall quaife so I didn't use drop gears. I use 16 inch wheels and a close ratio long box by Oppliger (built by Bara) I love the car on this set up and feels very keen the whole time.
smiley (15-07-2017)
So they do a 7" in 3.9 mark? Thanks for the info mate
smiley (15-07-2017)
Thanks mark, yes zetec turbo thats right but im looking to bullet proof as will be over 700 bhp
Dropped mine off at CTS this morning and decided to bite the bullet and go 3.9 CWP. Having new bearings and seals and a Quaife ATB fitted so hopefully I shouldn't suffer to much wheelspin at 400 bhp as it's 2WD
cossie fan (unluckerly)
Fit r888's and your have almost no wheel spin the the dry with warm tyres
Guys how bad is the 3.9 at motorway speeds?
most of my driving is in the forest and single carriage ways with 50/60mph limits.
Only go on motorways to get to shows etc then it's a fair drive etc, say 2 hrs each way.
Heard the fuel bill goes out the window on motorway as guess you are not on closed loop at the rpm the 3.9 sits at?.
what sort of cost is it to convert a 4x4?
Parts wise the drop gears and chain seem to be approx £250, and a non lsd 3.9 cwp diff about £100 them swap the cwp into your own lsd 7" diff?.
Cheers Paul
