Stack water temp sender
Old Jun 20, 2017 | 01:04 PM
GREENRS's Avatar
GREENRS
member
Default Stack water temp sender
Just had a Stack 52mm water gauge fitted to my cosworth and it goes straight to 120 degrees from cold and stays there is it a faulty water sender unit that came with the gauge I wonder?
Old Jun 20, 2017 | 01:19 PM
Joris_FRST's Avatar
Joris_FRST
Check if you have a good ground (measure resistance) from the side of the sender to the block.
Old Jun 20, 2017 | 03:22 PM
Caddyshack's Avatar
Caddyshack
Stack tech help desk are also pretty good with help and advice
Old Jun 21, 2017 | 09:15 AM
t230's Avatar
t230
def ground - are you using the sender that came with gauge or your own sender?
Old Jun 22, 2017 | 07:16 AM
GREENRS's Avatar
GREENRS
member
I had the sender fitted that came with the 52mm gauge 1/8 bspt
Old Jun 22, 2017 | 07:40 AM
t230's Avatar
t230
i had the same trouble after trying one of those ye olde £5.99 chinese jobbe and did same thing so i gave up...im no electrician but make sure you use the little washers when straping the ground etc....
