General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
So whats the biggest brakes you can run under 17's ?
I currently have 324mm discs on front and standard cossie discs on rear. A mate has 370mm front discs which is route i was going to go but later found out only 18's will clear them and i dnt want 18's been there don that i like to drive the car hard so 17's are perfect.
Comps MOs you can get 356mm on a 2wd and 343mm on a 4x4 with the correct AP calliper.
Ive sorted it now bud, 356x35mm front discs from Reyland with mercedes 4pot brembo calipers which I bought for Ł65 delivered, and 325x28mm rear discs from Reyland. Got to get brackets fabricated thats it.
The fronts are actually 32 mm wide, not 35. Remember that when ordering. . And the rears are 20 mm wide, but that is just a standard kit from Reyland.
