Fault code P0171
Old May 21, 2017 | 05:23 PM
focus on ford's Avatar
focus on ford
Default Fault code P0171
Hi ALL, can any one tell me what I need to put right this fault? This is on a ford focus 2002 thanks Paul.
Old May 21, 2017 | 06:06 PM
That fault code is a lambda sensor. If you google the code you should get plenty of info. You might just need a lambda sensor.
Old May 22, 2017 | 07:00 AM
oldford's Avatar
oldford
It's more than likely that there's nothing wrong with the oxygen sensor.
Usually this means that the engine is not getting enough fuel.
Common causes are an air leak on the intake side, a deteriorating airmass sensor, low fuel pressure. If the car is using a lot more fuel than normal it could be an air leak in the exhaust manifold or a defective/slow oxygen sensor.
