fooking mot station just nearly killed me"I THINK"
puts the car in for mot on thursday fails on coroded
back brake pipes so sez to the man ok you do the job
i put in a new handbrake console on friday after ive
finished the brake warning light comes on so THINKS
ive just knocked a wire will sort it next week ???
so i havent drove the car all weekend
just been to a mates to pick up some dvds
the brakes go dead wierd pedal seems slack and then goes hard
parks up flips open the bonnet BRAKE reservoir is empty
so gets a bottle of fluid out the boot pours it in it disappears
AGAIN looks under the car theres fluid pissing out of the bottom
of the abs pump THE BOTTOM 10M NUT IS NOT TIGHT
lucky enough had tool box in the boot"ITS A FORD THING"
TIGHTENS IT UP gets some fluid from local petrol station
light goes off brakes now seem ok..
i was supposed to be going to blackburn over the weekend
dread to think what could have happend on the motorway
NEED ADVICE im shure you bleed the system through the pump
am i correct IF SO GONNA KILL SOME FUCKER ON MONDAY
THE NUT WAS FINGER TIGHT cars a 2ldohci sapphire g reg
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
if that had of been me i would have called the AA or RAC there and then for breakdown recovery (and therefore an individual inspection of the fault) and then been after the MOT garage for a few ££££
Originally Posted by Matt @ CAE
he replaced the back pipes theres no new ones going into the pump
but im sure you bleed the system from there DOES ANYBODY ON HERE KNOW
The ABS pump is used to pressurise the rear brakes when bleeding them but no .... You don't bleed the brakes from the ABS pump - i.e. the garage shouldn`t have even touched the ABS pump in anyway.
better ta ask first sometimes instead of
just pondering will they need bleeding again NOW they seem ok ??
