Reccomended Repairers for L8 ecu
Hi folks does anyone know of places they can reccomend to repair a L8 ecu, the long and short of it is the ecu has failed causing the car to run on 2 cylinders no pulse to the other 2 at all. Tried another chip to rule the chip out and its exact, The car runs fine on my spare L6 but i need that for something else
Much appreciated in advance
Location: it's not where you are, it's where you've been and where you hope to be
mine had a faulty driver transistor on one injector channel which was easily repaired its a BDX53C iirc - prob get them on ebay. that said, its unusual for 2 channels to fail at the same time as they each have thier own transistor. might have resulted from a harness short. was it working on your car or did you get it in faulty condition?
It was working on the car ran it on there for well over a year, the day it happened we went shopping all was fine, went home then went to go out in it 30 mins later and 2 cylinders only, i checked through the wiring and no faults were evident
contact www.rp-lab.com
email: sales@rp-lab.com
they know everything about the weber marelli ECUs - and I am 100% they can help you out.
they have my highest recommendation
