anyone on here work on audis?
Old Nov 20, 2016 | 04:00 PM
andy130's Avatar
andy130
Default anyone on here work on audis?
have 2010 b8 a4 2.0tdi here was lumpy idle, changed injectors/rail sensors, changed the pressure control sensor on top fuel pump rev'd the car up an it cut out, wont start since that, any help guys would be great as need car going for work in morn
Old Nov 20, 2016 | 04:46 PM
burnzy's Avatar
burnzy
burnzy
Have you scanned it for codes? Pretty pointless without, you bled all the air out the system too, I can't remember if the 2.0tdi is common rail with the injectors visible above the cam cover, if so can you crack the unions and is diesel coming out of all 4?
Old Nov 21, 2016 | 09:06 AM
iansoutham's Avatar
iansoutham
OCD Victim
Sounds like fuel drained back when the system was split. You started it on what was there and when the pressure dropped due to lack of new fuel, it pulled air.
You would probably need VagCom to run the lift pump if fitted and rebleed.
If there is a fuel filter visible, make sure it is full of fuel as well before starting.
