My new big valve cylinderhead!
Looks like a cracking bit of engineering. I've heard of the golf ball effect being used on inlets but never on the head itself. Who did the work Bart?
It was already a big valve rallycross head which i got reworked with extra porting and berrilium valve seats. Also has mechanical followers and rallycross spec cams which have huge lift.
Have to build my bottem end now.
Already have a nicasil linered block with 10 long studs and billet main caps.
Thinking of stroking with 84mm crank to get 2,2 liter engine with twin scroll 9174 turbo.
Also building a one off inlet manifold with ITB and MIS cover.
Should give good power and response.
It was done by Veicomer. The dimples improve flow and atomatisation of the fuel which should give more power.
Looks amazing never seen that done before the dimple effect
burnzy
I want to see the colour of your pants when it's driven in the wet
Lovely bit of engineering, bet it took some time putting them dimples in, was it done by hand or machine?
That is a very well engineered cylinder head, not seen the dimpling done before but if it helps performance why not. Your engine specification sounds like big BHP? Your 2wd Saff will certainly get up and go when your new engine is installed.Should certainly suprise a lot of newer cars!!
mark
and didnt see improvements , a golf ball still has air passing over it so same theory , a f1 car or moto gp bike isnt a plane but still has wings lol
mark
mark
Wow! Looks like there's another monster being created, sounds like its going to be a missile when its finished.
Mark
Potatoes, pot art Oes.
manuel boeckx (26-11-2016)
i can see the theory behind it in the sense in aids atomisation and gives a better enter the cylinder head. ive allways gone by the rule (on 2 strokes) that a polished surface is good in combustion chambers and post combustion for the simple reason it helps reduce carbon deposit build up. on the induction side ive allway beleived a textured finish helps prevent the air/fuel entering the chamber seperatly. wether the dimple theory works or not i only have your word for it but it looks brilliantly excecuted.
J40davies
15-02-2017 11:30 PM
Garage19
11-06-2009 04:43 PM
twinkle_2k86
01-08-2006 05:53 PM
