Rear brake balancer on 3 Door Cossie
Old 02-10-2016, 01:26 PM
johnlboyer
johnlboyer's Avatar
Default Rear brake balancer on 3 Door Cossie
Hi guys, hoping someone out there can help me. My 3 door was in for MOT a couple of weeks ago. It passed, but I was made aware of an issue with rear braking system. There is an inline rear brake valve/ balancer in front of the nearside rear wheel. This item is leaking slightly, and the tester said it needs replacing. I have been advised that a Ford replacement is not available, but a similar Jaguar part fits and does the job, but again does not seem to be available in the UK. I have tried a couple of Jaguar dealers in the US but neither have the part. What is the way round this problem. Any help would be appreciated.
Old 02-10-2016, 10:14 PM
wildheart
wildheart's Avatar
Is this the part? http://www.ebay.co.uk/itm/2626423769...84.m1555.l2649
johnlboyer (06-10-2016)
Old 03-10-2016, 02:16 AM
dojj
Resident Wrestling Legend
dojj's Avatar
If it's a cosworth it should have abs and therefore no bias valve
They were only fitted to non abs cars
Old 06-10-2016, 09:16 AM
johnlboyer
johnlboyer's Avatar
My car has ABS and rear brake bias valve.
Old 06-10-2016, 09:35 AM
johnlboyer
johnlboyer's Avatar
Default Brake bias valve
Originally Posted by wildheart
Hi, thank you for that. Yes, that is the part, well spotted. I have purchased it just in case a new one doesn't come up. Same part fitted to earlier Jaguars but also not available here or in USA. It would seem that this problem will pop up on many Cossies in the future. Maybe a specialist engineer will look at re-furbing these!!!!
Old 06-10-2016, 11:51 AM
Cragrat
sit boo boo sit
Cragrat's Avatar
You sure Dojj ??
Mine too
Old 06-10-2016, 01:02 PM
PAUL S
PAUL S's Avatar
They all had them, and they all leak! the 4x4 ones were just under the abs valve block though if I remember correctly.
I have seen aftermarket ones for sale but cannot find a link at the moment sorry
Old 06-10-2016, 03:27 PM
Cragrat
sit boo boo sit
Cragrat's Avatar
Yup I can confirm he is correct "they all leak "!
Old 06-10-2016, 04:10 PM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
They do have a pressure limiting valve inline to the rear brakes, 4x4 is attached to the valve block whereas 2wd is in the rear line at the rear of the car.
johnlboyer (07-10-2016)
Old 06-10-2016, 04:24 PM
Mark V8
Mark V8's Avatar
Is there any reason not to use the complete 4x4 valve body with pressure limiting valve on a 2WD car ?
Assuming the removal of the rusty 2WD valve
Old 06-10-2016, 04:33 PM
Martin-Hadland
No it works fine, I did that on my Mondeo. As far as I recall the outer pipes going into the valve block from the master cylinder need swapping around though, you'd need to check that as its been a long time since I did it. I actually found a near new 4x4 valve block the other day and thought I'd ebay it for the concours guys.
Mark V8 (06-10-2016)
Old 06-10-2016, 07:18 PM
Tim Wharton
Tim Wharton's Avatar
Hi
Had my Sapphire Cosworth one leak too
I've fitted an adjustable AP racing one seams to work well
I need to move it inside the car at some point as I fitted it in a hurry underneath to enable me to carry on useing the car.
Another job for the winter
I bought it from BG developments 01527873716
Cheers Tim
Old 07-10-2016, 09:51 AM
johnlboyer
johnlboyer's Avatar
What is the cost of the AP item?.
Old 08-10-2016, 10:28 AM
dojj
dojj's Avatar
yup, that bigger union i've seen on the valve block
the brake balancer is normally that bigger egg sized lump with the bar and stuff in it that's supposed to increase the braking on the rear if the vehicle is loaded and almost always causes issues (according to rsturbo owners) whenever they've just fitted rear discs or lowered the car and the answer was to split the valve open and cut the bar with a hacksaw blade
the abs always supplies a constant pressure to the rear brakes when the pedal is pressed i was lead to believe
Old 08-10-2016, 10:38 AM
Mark V8
Mark V8's Avatar
Is the angle it's mounted at important ?
Pic of mine before I striped the car...
Might pull it apart when I get the chance to see what's inside
Old 08-10-2016, 11:44 AM
dojj
dojj's Avatar
just replace it with a bit of pipe?
unless it does indeed reduce the pressure and then opening it up and resealing it might do the trick?
Old 08-10-2016, 01:36 PM
Mark V8
Mark V8's Avatar
I'll probably use all 4WD stuff apart from the ABS ECU.
Just curious really !
Old 08-10-2016, 05:31 PM
PAUL S
PAUL S's Avatar
I believe it holds residual pressure in the rear line once you come off the pedal, and it is there for a good reason so replacing it with a length of pipe is hardly common sense!
Old 08-10-2016, 08:44 PM
Tim Wharton
The AP adjustable valve was Ł140.78 plus vat and carriage
I did manage to get 10% off as the firm I work for buys a lot from them.
Quality item
Cheers Tim
Old 09-10-2016, 05:51 PM
PAUL S
PAUL S's Avatar
Here is an option
http://www.speedwaymotors.com/Speedw...rple,5312.html
and closer to home
http://www.demon-tweeks.co.uk/motors...pressure-valve
johnlboyer (10-10-2016)
Old 10-10-2016, 09:38 AM
johnlboyer
johnlboyer's Avatar
Thanks for that info Paul. Do you know which of the 2 would be required to replace the Cossie 3 Door original?. One is 2psi and the other is 10psi. I will probably buy whichever will suit as a spare. I bought the second hand one which was on E/bay recently, and might not be a long term solution. I will probably go with the Demon Tweeks item when I can be sure which to buy. Thanks again for very useful information.
Old 10-10-2016, 09:49 AM
johnlboyer
johnlboyer's Avatar
Getting back to the valve I recently bought on E/bay. The valve that is fitted at present is leaking. I take it that it is always the valve itself and not the brake pipe connections at either end that leak. If it is the case that the valves leak, is there any way of encapsulating the second hand replacement to prevent that happening prior to fixing?. The valves seem to comprise of three parts which I understand should NOT be taken apart. I also understand that the joints are subjected to high pressures.
Old 10-10-2016, 08:30 PM
PAUL S
PAUL S's Avatar
The 2 psi one is listed for disc brakes and the 10 psi for drum brakes from what I read.
Old 11-10-2016, 09:49 AM
johnlboyer
johnlboyer's Avatar
So it does Paul S. I should have spotted that. As the old saying goes, it's no good getting up unless you wake up. I think that applies to me !!!!.
Old 11-10-2016, 06:34 PM
tosh
tosh's Avatar
I know that the 2wd valve has 8.5 stamped on the body, would that be 8.5psi ? If that's the case would you have to match that if purchasing an after market one.
Old 11-10-2016, 07:19 PM
johnlboyer
johnlboyer's Avatar
Thanks for that Tosh. I won't buy an aftermarket part until I am sure that it does what the original did. I will check out the pressure rating with a man that will probably know .
Cauf61
04-09-2016 07:03 PM
B16CVH
Ford XR Parts For Sale
30-07-2016 03:59 PM
wedge07
12-07-2016 05:16 AM
Quick Reply: Rear brake balancer on 3 Door Cossie
