168 lph @ 5 bar enough for stage 3 Cosworth (greys)
Just bought an uprated fuel pump for my escort cossie, after removing the tank/sender I found that someone has fitted a different Bosch pump & modified the sender
The pump that's fitted atm is a Bosch 0 580 254 023 fuel pump
The flow rate is 168lph @ 5 bar, I'd this enough for my stage 3 set up (greys t35)
If not I'm going to have to modify the sender set up to accept my new pump
