Mk1 RS strange problem
04-07-2016, 03:22 PM
I've recently got myself a mk1 RS and love it but it's got a strange fault with it. Every time I put my blowers on and come to a stand still the car cuts out and when I turn the blowers off the car is fine lol.
Any ideas?
04-07-2016, 03:28 PM
Battery terminals and all earths clean and tight?
04-07-2016, 04:14 PM
As above or alternator . Take it to the old boys in Hockley (start right ) next to the Esso garage . Their excellent in there .
04-07-2016, 05:00 PM
Quote:
Originally Posted by
RichieST
Good shout will check that.
04-07-2016, 05:01 PM
Harris.
Yeah I know them, they have been there for years.
04-07-2016, 05:52 PM
had this problem with fan cutting in ..check belt tension as well - new drive belt cured mine but also chek ur tensioner pulley as well
04-07-2016, 07:06 PM
t230
Cheers fella will do
04-07-2016, 08:05 PM
If you disconnect the battery for 10/15mins and then reconnect it, start the car and turn everything on: lights, fans, aircon etc and let it idle for 10/15 mins and it should relearn the idle. It may also be your MAF though as mine did similar things when it was on its way out.
08-07-2016, 11:15 AM
Right had the alternator checked and it's all good. The car only does it once I've stopped as when I'm driving it's fine. Relay or resistor or as above said " MAF "?
08-07-2016, 11:44 AM
mk1 rs what?????
mk1 escort?
mk1 focus?
08-07-2016, 05:07 PM
Ford allegiance
london_chris
mk1 rs what?????
mk1 escort?
mk1 focus?
Does a mk1 escort have a MAF
08-07-2016, 11:51 PM
To rule the maf out unplug it and if it rus fine it's the maf they run off memory when the maf is unplugged could also be an air leak too
09-07-2016, 06:31 AM
anthony lea
No but there is no info on the first post about it. Only on the later posts on replying from what a garage has suspected what's wrong.
If it's a mk1 focus rs I'd say either your idle speed control valve has an issue or you've got an air leak.
10-07-2016, 07:14 PM
lol sorry guys its a focus RS
siscossie
13-06-2016 05:19 PM
DAN@ADRIAN FLUX
Shows & Track Days
11
02-06-2016 01:36 PM
rich724
20-05-2016 03:41 PM
siscossie
16-05-2016 05:40 PM
Jasoncmor
12-04-2016 06:16 PM
