Boost Fluctuating..
Old Apr 7, 2005 | 10:14 PM
K18NEO's Avatar
K18NEO
Default Boost Fluctuating..
Hiya all.
I have a Series 2 Rs Turbo in my mk5.
Ive recently had samcos, -31, it was already chipped, full oil change, distributor, rotary arm, cap, sump, full water change, and general go over. Its now been set up to 10psi on the actuator. Ive recently fitted a bleed valve and it now boosts to 14psi, but the problem is, it boosts and fluctuates to 7psi....
1st gear : duno, wheel spins LOL
2nd gear: 14peak, 7 hold.
3rd gear : 14peak, 10hold.
4th gear : 14peak, 11 hold.
5th gear : 14peak, 11 hold.
I defininatly feel i have a problem, could i have a list of problems i could start to work thru guys please?
Thanks!!!!
Old Apr 7, 2005 | 10:16 PM
EIL132's Avatar
EIL132
The boost will drop from peak.
Old Apr 7, 2005 | 10:18 PM
K18NEO's Avatar
K18NEO
that extensive?
Old Apr 7, 2005 | 10:26 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Depends on actuator really, but yea it can be, if anything your actuator may be a little weak! but you' always get the boost tailing off no matter what. ..
Old Apr 7, 2005 | 10:28 PM
Whats fluctuating about that... ?
Peaks the same.
More in each gear is down to load.
Old Apr 8, 2005 | 08:24 PM
K18NEO's Avatar
K18NEO
yeh but its quite a big difference, dropping HALF in second gear... there must be aproblem..
Old Apr 8, 2005 | 08:31 PM
G420 DEL's Avatar
G420 DEL
neo a-regs fezzi peeks 15 n holds 10
so doubt there much wrong really.......specially wi most ppl here sayin its right
leave it till summot really does break then worry bout that
Old Apr 9, 2005 | 06:59 AM
K18NEO's Avatar
K18NEO
LOL... cheers then lads and maroo
Intercooler next then!
Old Apr 29, 2005 | 12:05 AM
jim diesel's Avatar
jim diesel
hi mate i see uv got an rs turbo motor in ur mk 5 ive done the same but i would like to no if u used a rs turbo fuel or not because im tryin to sort a prob with mine it cums on boost and drives just fine apart from when u boot it, it seems to pull just fine till u get to about 4500 rpm then the power just seem to tail off its like someone just thown an anchor out the back. this seems to happen in ever gear if anyone can help that would be great. cheeRS
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
