A Big End Bearing discussion Please.....
So what is the best YB big end bearing to use?...I have been told std Cosworth...but surely there is a heavier duty item which can last longer...as lets be honest a refresh means bearing changes so using heavier duty means longer between refreshes???
Or am i getting it wrong and any bearing even a std pinto bearing would last the same amount of time????
Educate me please my komradz
Mark has said std bearings......but as usual am finding out from ALL sides and then forming my own opinion (Proper DIY )
No disrespect to Marks knowledge BTW!
DEYTUKURJERBS
IMO std bearings too, always.
IMO uprating bearings is only a way of masking an oiling problem thats fucking the std bearings, if your oil setup is adequate there should be no wear on the bearings whatsoever.
Preventions better than Cure
Mark is 1 of probably a very few people willing to advise/help/assist you in your cornflake dream cossie and his reputation is 2nd to none, Take his advice and just build the bloody thing.
You are kidding aint you? Do you know i supply most tuners?...Never had anyone on the phone tell me to fook off for advice....there is a real life off the net you know....
So again...
std genuine bearings are made by vandervall and they have been the best bearings for years...they are tried and tested........so go with whats known
AE bearings are absolute pony
So again...
Really ???????????????
Turn your head around and let the other face speak
The tuners may actually despise me but they know a good bosch deal when they see it
Must admit Mark is my favourite...great to talk to...dont bull shit..(not that the others do!)...i just seem to get on best with Mark Maybe i am just gay
Standard bearing will be fine, because
a. you will never finish it
b. you wont get any miles out of it.
Dingy if i will never finish it how will i get to the limited miles stage?
You gonna be surprised as are alot of doubters...it mystifys me why you think it wont be done
Originally Posted by Alg1k
DO THE BEARINGS TOUCH THE CRANK THEN AT FULL BOOST ?
Sorry caps off
Sorry caps off
Alex
Vandervell are now ACL BTW
learn something every day
Do you need uprated ones then
the oil is between the brg face and crank journal, but you still see a loadin of about 2 tons on comp/ign stroke on the brg face albeit using an oil interface to stop contact
so i would give that a great big fooker of a YES!!!!!
and the rest my friend
If you use a harder bearing then it can take a bigger shock load, so better for a 800bhp engine for a short period of time, if you want it to last though then go for a nice soft std bearing, because it wont kill the crank the first time a minute bit of swarf tries to embed itself and the bearing wont let it and pushes it back onto the crank instead.
As a general rule any "race" part is good for huge power and shite for huge miles, manufacturers use the bearings they do because they can last a long time.
Thats the fundamental problem with your idea of building a massive power engine then turning the wick down and using it as a normal engine, it just wont last.
P2B clearances are another example of where you want the total opposite for power and reliability.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
