Anyone on here owned a EP3 ?
my mate loves them..dont rag it from cold..till it warms up,check your oil level because hes was low on oil and the vtec system dont work.. i think they are solid cars and good fun if driven hard..but aint quick ..the clio 182 cup i had was quicker ..BUT the civic type r is still a good car and very reliable.. ill find the sticky where common faults are listed if i find it
**RS COSWORTH**
I've not owned one but driven plenty. Valve clearance is common
Check oil regular as they do like to use oil.
Mods wise
Uprated cams
air filter
throttle body
exhaust
remap ( not sure if you can map a standard ECU yet ones I've driven had afteramrket ECU's )
Decent suspension (or Eibach lowering springs)
Sway bar
polybushes
Limited diff
All the above makes it so much better but its not cheap and should see around 250bhp and similar torque not massive increase but makes it so much more torquey down low.
Mods wise
Uprated cams
air filter
throttle body
exhaust
Sway bar
polybushes
Limited diff
admanrs
20-03-2017 07:21 PM
3dr cossie
30
08-04-2016 08:30 AM
Prince_Thain
24
30-03-2016 05:24 PM
