Spark plug gaps?
Old Mar 26, 2016 | 07:03 AM
jdsjojo's Avatar
jdsjojo
Default Spark plug gaps?
What have people set there's at?
Just changed plugs and it's misfiring under boost. Had this last year when I changed the plugs.
I've set them to 0.8 but have got MSD wasted spark kit. Thought it would piss it at that?
380hp saph on AGPR902P's
Old Mar 26, 2016 | 10:59 AM
martysmartie's Avatar
martysmartie
I would have thought they could be larger, given you have WS.
Martin
Old Mar 26, 2016 | 11:48 AM
gcfcos's Avatar
gcfcos
On my saph I set them to 0.6 on standard ford plugs
Old Mar 26, 2016 | 01:16 PM
scoooby slayer's Avatar
scoooby slayer
im sure I used to run 0.6 gap
Old Mar 26, 2016 | 08:36 PM
jdsjojo's Avatar
jdsjojo
Have gone for 0.7, will give it a blast on the way to work tomorrow morning and report back.
Ta macho xxx
Old Mar 27, 2016 | 12:47 PM
COLEYST200's Avatar
COLEYST200
.6 should be ok mate just so you no you cannot run a big gap on a Cosworth even with wasted spark as the boost blows the spark out . All so check your leads are not to close to each uver as that can cores problems all so
Old Mar 27, 2016 | 01:07 PM
jdsjojo's Avatar
jdsjojo
Cheers mate. I blasted to work this morning because I couldn't work out if it was 4.30am or 5 30am! Anyway it was to coughing at top end so have just reduced them again. Now at 0.6 like you say. Will give it a go. Poweeeeer
Old Mar 28, 2016 | 09:16 AM
martysmartie
You should be able to, the reason this is done on the standard system is due to the weak spark.
WS provides a stronger spark, which is one advantage.
Martin
Old Mar 28, 2016 | 10:38 AM
COLEYST200's Avatar
COLEYST200
Martin
You might be right but from my experience if the gap is just a tuch rong even on wasted spark they will play up . When I sent my focos to be set up my tunner told me to put a MSD coil pack on the car as the standerd ford coil pack can all so struggle at hi boost .
Old Mar 28, 2016 | 06:55 PM
jdsjojo's Avatar
jdsjojo
Right update... after trying 0.8, 0.7 and 0.6 on AGPR902P's I have come to the conclusion that they are total wank. Had misfires on boost with the bigger gap and yo-yoing idle with the smaller gap to the point that the engine was nearly stalling at lights!
Am now back on trusty 071's gapped @ 0.65mm and was on full boost all the way home with my cock in my hand! No problems what's so ever.
071's all the way! No need for any others ðŸ‘ðŸ Poweeeeer!
Old Mar 28, 2016 | 07:43 PM
gcfcos's Avatar
gcfcos
071's all the way! No need for any others ðŸ‘ÂðŸÂ Poweeeeer!
Happy days I had so many people telling me when I first got my Cossie to run denso and all sorts of other make plugs, they all made it run like a bag of shite so I went back to standard ford plugs and I haven't suffered a single misfire ever since! Only when it does start to misfire at least once a year I know it's spark plug change time and then it's good for another year at least lol!!
jdsjojo
May 27, 2016 03:59 PM
jdsjojo
40
Apr 10, 2016 08:20 PM
gcfcos
11
Mar 21, 2016 10:40 PM
jdsjojo
Mar 21, 2016 01:17 PM
cozzy jeff
11
Mar 20, 2016 07:47 PM
