Are towbars programmed?
Old Feb 22, 2016 | 05:31 PM
RichieST's Avatar
RichieST
Default Are towbars programmed?
Evening
I have bought a 2011 grand Cmax and it has a Witter towbar with single electrics that I would like to remove as I have no need for it.
Are the electrics just plugged in or is it a bit more complex than that? The car has the automatic park assist feature which I presume is set not to opertate while towing, so not sure if just unplugging it will cause any problems.
Thanks for any help
Rich
Old Feb 22, 2016 | 05:45 PM
I would of said it was just all plugged in. Or even with scotch locks lol.
With cars these days it might be more than that.
Have you put the mondeo back to standard then to trade it in.
Old Feb 22, 2016 | 06:00 PM
jamie956's Avatar
jamie956
its likely to be programed into the ecu, I know its a bit more modern but a mate has just got a 15 plate VW t5 and wants to fit a tow bar and that needs the ecu up dating apparently it also affects the braking performance when towing, the days of scotch locking are long gone.
Old Feb 22, 2016 | 06:12 PM
RichieST's Avatar
RichieST
Thanks for that, I will have a look at how it is all fitted in then go from there. I've been on a few sites that sell them and you can either buy a universal electrics kit or a vehicle specific kit, so will have to see. I had a mk3 Mondeo that had the wiring scotch locked in, looked a right mess!
Yes glenny all standard now apart from the kit that is glued on. Got all the sound system out and the wheels off. Got some serious ebaying to do!
Old Feb 22, 2016 | 06:18 PM
Adam-M's Avatar
Adam-M
Planning on a bigger family Richie?
Old Feb 22, 2016 | 06:25 PM
DangerousBryan's Avatar
DangerousBryan
If it's not a Ford towbar you should be fine. Nothing you do will disable the car. Just take it off and see what happens.
Old Feb 22, 2016 | 06:55 PM
RichieST's Avatar
RichieST
Thanks Bryan,
Im happy to stick with 2, but the wife and girls seem to need to take everything but the kitchen sink every time we go out so need to upsize from the monshito
Old Feb 22, 2016 | 08:33 PM
martysmartie's Avatar
martysmartie
It depends on how it's been fitted, but if it's CANBUS, yes, it's programmed.
Martin
Old Feb 22, 2016 | 08:54 PM
v6gerry's Avatar
v6gerry
Ive had 2 towbars fitted in the last 4 years 1 was a 54 reg focus that was scotch locked with a live feed from fuses behind glove box, I removed bar and elec when I sold it , and last year my Honda CRV again the guy scotch locked wiring and took a fused live feed from battery , hope this helps !
Old Feb 22, 2016 | 09:16 PM
Your speakers will go well in my focus lol.
Old Feb 22, 2016 | 09:19 PM
RichieST's Avatar
RichieST
Pm me then
Old Feb 22, 2016 | 09:20 PM
RichieST's Avatar
RichieST
Yes thanks for that, I am hoping to see a load of scotch locks and not any fancy modules!
You will be wanting more then i can afford. Did you have a different head unit too.
Old Feb 22, 2016 | 09:22 PM
RichieST's Avatar
RichieST
No running off the standard headunit as it has the nav, Bluetooth and climate etc. Used a signal processor to feed the amps!
Old Feb 22, 2016 | 09:29 PM
How does the signal processer work then.
Old Feb 22, 2016 | 09:33 PM
RichieST's Avatar
RichieST
It takes the signal from the headunit, which usually has its bass turned down etc to save the standard speakers, and converts it to a perfectly flat signal for the amps to amplify, so you aren't just amplifying shit from the standard headunit.
Old Feb 23, 2016 | 06:29 PM
Cool matey.
cossynut2
28
Nov 8, 2019 07:25 PM
j.hammond1
Feb 16, 2016 04:05 PM
jimhc
Feb 16, 2016 03:28 PM
rich201283
Feb 6, 2016 08:17 PM
