cosworth thermostat area corroded on head?? fix??
my cosworth 2wd head is corroded/pitted where the thermostat housing buts up against it
im now using the 4wd thermostat housing on this so it only seals on an o-ring
my concern is this will leak, any ideas on a repair while the head is bolted on???
I was thinking of using a 2wd gasket but it doesn't have much of a mating surface on the 4wd stat housing?
A skim of chemical metal to fill in the pitting should work (as long as surfaces are mega clean beforehand).
Ultimately weld and skim will be required for a more permanent fix - but appreciate this isnt going to be do-able with the head in place.
Plenty of sealers about for all sorts of things.
Stat housing on my Isuzu 1.7td just bolts up dry to the iron block. ie no gasket, just sealer and it's a pretty shitty surface !
I'm amazed it doesnt leak ( well it did eventually but just needed to clean and re-seal it )
Doubt tigerseal would be rated for engine temperatures though.
Plenty of Loctite sealants rated for high temperature and with good gap filling abilities.
http://www.loctite.co.uk/gasketing-9224.htm
155lee
25-02-2016 09:02 PM
Mungus
02-02-2016 09:27 AM
