SPA boost/temp gauge
#41
Porkie, first you need to access the gauge menu system. You do that by holding down the red button and then switching the ignotion on.
Now that you reached the menu system you navigate the options by tapping the read button. When you reached a option you would like to change you hold the button down for a while.
Quick tap = next option
Long tap = change current option
Example:
First option that comes up when you access the menu system will look like this on the display:
bl
This controls the gauge backlighting, hold the red button to switch it on or off.
Next menu option is:
rt
PE
This resets the gauge stored peak values, hold the button to reset.
When you are done just switch igniton off. Sometimes you cant access the next option after changing another so you might have to switch off and access the menu system again.
For more information RTFM.
Example:
bl
rt
PE
#43
Originally Posted by Sean Bicknell
Nice try mate, but I know Pork chop, you would have lost him before the end of your first sentance
#44
Mate he still lives with his mom!!!!!
And I kid you not, he will be up in his room and call his mom downstairs on his mobile and TELL her to bring food and stuff up to him!!!!
#46
Originally Posted by Porkie
Gonna rip this dash set up out and remount all the gauges, switches and fuses and make it look alot more pro
#48
well if your using the temp for ACT then you need to screw both sensors into the plenum tap the plenum for the sensors.
1/8NPT Temp
1/8BSP Press
you need to use the dowty seal provided with the pressure sensor and PTFE tape with the Temp sensor as its tapered
Once the sensors are in just wire up the gauge
Red to 12v accessory switched feed and black as directly to chassis as possible (not to loom earth)
Thats about it i think
1/8NPT Temp
1/8BSP Press
#52
Originally Posted by Westy
the big thing with SPA on it? where in the plenum is that meant to go
1/8BSP Press
1/8BSP Press
#55
Originally Posted by Andreas
Live the dream
My cleaner has the easiest job in the world as I stay with my mum all the time so the house never gets dirty she just comes round and watches TV for a few hours and charges me £20
Living with my mum rocks though, I have 24 room service
Seans coming down to stay this weekend... he will be in my house on own his own as I will be at my mums
Also Andreas thanks for the instructions, I printed em and will be using that I can't read the manuals as Martin fitted the gauges and therefore he would have lost the instructions
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
