3dr and 2wd saph fuse boxes the same?
My mates got a late 2wd saph cos and he's wondering whether the 3 door fusebox is the same as he needs a new one for his saph but found a 3dr one for sale. Any help would be much appreciated. Thanks
Originally Posted by martysmartie
It will be the same as a high spec MK2.
Martin
Martin
Originally Posted by costina
As Martin said any high spec mk2 will do.
I am guessing its got a bit hot and melted a few fuses???
Fan fuse, fuel pump and sometimes headlights if high wattage bulbs are fitted.
Originally Posted by cossynut2
Usually the radiator fans fuse, I had a seperate fuse holder done years ago and never had a problem since.
Resident Wrestling Legend
Replacing the box is easy, just file this simple guide:
Locate fuse box
Remove car from fuse box
Rebuild the box with a spare one
Rebuild car around fuse box
But yes, the box does split and any replacement you can find should have all the bits you need to fix yours
Locate fuse box
Another advantage with rewiring, is that you reduce the load on the overloaded fusebox.
Yes, there is nothing special about Cosworth's, they are merely high spec models, i.e. Ghia trim.
Martin
Correct, but it should be rewired, but doing this alone does not solve the underlying cause, that being the fans stay on for too long, due to the span of the switch. This along with the fuel pump wiring are two common issues and both have the potential to cause catastrophes.
Martin
Martin
liamT74
24-12-2015 05:48 PM
-=Cossie=-
04-12-2015 06:12 PM
