Rs500 bumper problem
Old Nov 3, 2015 | 10:26 AM
InFlammen's Avatar
InFlammen
Default Rs500 bumper problem
Hello.
I'm just restoring my 3dr Cossie and I have a problem.
The car came with a fiberglass front bumper, and I have purchased an original 500 one. It all seems fine (wings, brackets, etc not damaged at all). But when I try to fit it, there is a quite big gap between the bumper and the wings.
Could anybody give me an idea about what could be the reason and how could I fix it?
Many thanks.
Old Nov 3, 2015 | 10:36 AM
martynhomer01's Avatar
martynhomer01
There are two flap like pieces of metal which are attached to the wings, that hang down behind the bumper on the sides. The clips for the bumper locate into these pieces. With mine, I gently pushed them in towards the engine bay until the bumper sat right. Takes some fitting and re fitting, but it will go eventually.
Old Nov 3, 2015 | 11:21 AM
InFlammen's Avatar
InFlammen
I already have tried to do that. Well, perhaps I have tried too gently.
Could you give me another tips?
Old Nov 3, 2015 | 09:51 PM
PAUL S's Avatar
PAUL S
The RS500 bumper is wider than a 3dr one, it can be quite a task to get the gaps even and looking good. It was done for a reason, as the touring cars could then have the wings pumped out at the bottom to achieve greater wheel travel. Takes quite a bit of adjusting to get it looking ok, and even then the gap is quite large both sides.
Old Nov 4, 2015 | 09:21 AM
R4N SS's Avatar
R4N SS
When i changed my bumper from a standard 3dr to RS500 version i dont recall it being that much of an issue. Yes we did have to fettle it a little to get the gaps even all the way round
Old Nov 5, 2015 | 07:18 AM
Mr RS500's Avatar
Mr RS500
Thee are loads of pictures of rs500 front bumpers fitted on here
www.rs500owners.com
Look in the resto section for best results
The 500 bumper should fit exactly the same as a 3 door
Old Nov 6, 2015 | 09:51 AM
InFlammen's Avatar
InFlammen
So we can consider it as a direct fit but not perfect fit?
Old Nov 6, 2015 | 09:53 AM
InFlammen's Avatar
InFlammen
www.rs500owners.com
But those are RS500, not standard Sierra RS, so they probably have some slight modification in order to get perfect fitment, isn't it?
Old Nov 6, 2015 | 01:15 PM
AndyPen's Avatar
AndyPen
Some of the 'mushroom shaped' genuine Ford fixings are actually longer than others. I was caught out by that until I saw the two side by side.
Old Nov 6, 2015 | 02:21 PM
R4N SS's Avatar
R4N SS
They do go straight on but you have to fiddle with them to get them to sit right with the correct gaps alround
Old Nov 6, 2015 | 04:14 PM
InFlammen's Avatar
InFlammen
Thank you all!
All this info will be a great help for me!
Old Nov 6, 2015 | 06:07 PM
Mr RS500's Avatar
Mr RS500
No they dont
The rs500 shell is a totaly std 3 door shell , and the bumpers are exactly the same other than the cut outs
They all fit identical if you spend time fitting them correctly
Old Nov 6, 2015 | 06:26 PM
InFlammen's Avatar
InFlammen
No they dont
This is the only point that I do not totally understand.
It seems clear to me that it takes a bit time to fit the 500 bumper, but... is it wider than 3dr or not?
Old Nov 7, 2015 | 08:43 PM
thebronze's Avatar
thebronze
Blag Master
NO!! same width
Old Nov 9, 2015 | 08:51 PM
PAUL S's Avatar
PAUL S
Never measured one side by side with a 3dr version, but always found that the side gaps were slightly bigger on RS500 bumpers whenever I tried adjusting them compared to the 3dr version.
The race teams unstitched the front wing lower mounting points on the shells where the bumper also attaches and fitted a spacer to pump out the wing and allow more room for the bigger wheels and tyres and my thoughts always were that the 500 bumper was slightly bigger to accommodate this.
Pretty sure this was why the eggenberger cars were disqualified from the Bathurst win as a standard road car was checked for clearances which brought the practice to light.
Could well be barking up the wrong tree though.
Old Nov 10, 2015 | 04:30 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Mine was exactly as you describe.
Old Nov 10, 2015 | 08:41 PM
Mr RS500's Avatar
Mr RS500
3 door and rs500 are exactly the same size
However Paul has piked up on a good point
My front bumper on my Lui eggenberger car has a front bumper that is 20mm wider than the other 3 rs500 bumpers i have on the shelf , so im sure that some were made wider for eggenberger
These pics show the fitment on a std rs500 and is the same as a std 3 door ,, all these are differant cars
Old Nov 10, 2015 | 08:45 PM
PAUL S's Avatar
PAUL S
Does the bottom mounting point on your wings have the spacer behind them Paul compared to a standard cosworth shell?
If not maybe they all removed them after Bathurst.
Old Nov 10, 2015 | 09:03 PM
Mr RS500's Avatar
Mr RS500
No it doesnt ,, but the bumper has a massive gap compared with any road car due to the spacers being removed and the wings back in the std place
Old Nov 10, 2015 | 10:23 PM
PAUL S's Avatar
PAUL S
The cheating buggers! same with those egmo RS500 blocks full of metal in the waterways
andy130
Dec 5, 2015 03:16 PM
InFlammen
Nov 16, 2015 09:01 AM
martynhomer01
Nov 4, 2015 09:49 AM
bull-turbo
Nov 2, 2015 05:57 PM
Beach
Nov 1, 2015 06:03 AM
