Setting my Orion up efi turbo
Hi guys can any of you help with me setting my Orion up rite I have took the zetec out put efi turbo in the car is ruining beige injectors 195 chip t3 turbo grs cooler stage 3 cam just a ruff set up for boost and fuel pressure thanks guys
Running OFAB/OFAC? You can't really set them up, the chip will expect fuel pressure to be as a standard untouched regulator (3 BAR) and boost is probably 1 BAR for those chips but I'm not sure. No idea about the cam either, does the chip expect a stage3? Does it expect beiges?
You took a Zetec turbo out and replaced with a CVH?
As Matt says there really is only the base fuel pressure and the CO pot to adjust, if your chip is correct for those injectors and that turbo and there are no faults it should run just fine.... But I find there is usually something broken these days!
mk3ste
17-10-2021 11:09 AM
Mark RS
12-10-2015 07:01 AM
