500+ engine starting problems
Old Oct 27, 2015 | 07:11 AM
  #41
Bart's Avatar
Bart
Any updates?
Old Oct 27, 2015 | 03:28 PM
  #42
SHaDoWLanDZ's Avatar
SHaDoWLanDZ
Boost = life
Yes.. finally got the plugs today.
1 set of IK27 and 1 set of... Ford Motorcraft AGPS092C1 .... i dont have a clue what these are.. but i got them from Matt Lewis.. strange as he was going to send 071C... anybody knows what these are?
Old Oct 27, 2015 | 05:07 PM
  #43
SHaDoWLanDZ
Boost = life
Anyway, the car starts after 2 times cranking on IK27 with (out of the box) 0.6mm gap.
AFR after 4-5min is 12.5-12.7 so i guess too rich..?
When i give some trottle it goes to 13.0 and back to 12.5
This has nothing to do with the gap i suppose.. also i give trottle to 4000rpm i feel a few "hick-ups"... Engine not warm enough to perform OK? Gap to small/big?
Old Oct 27, 2015 | 05:43 PM
  #44
SHaDoWLanDZ
Boost = life
Here is the video what i mean.
I hold my foot at exact the same rpm first (ą3000rpm)
The needle fluctuate between 3000 and 5000 even tough i don't push more or less.
Is it because of a bad spark/gap?
Old Nov 2, 2015 | 10:47 PM
  #45
SHaDoWLanDZ
Boost = life
Reason for having a tighter gap acording to Oppliger Romain:
Difference between race-engine (like mine) and a road-engine, is the power and pressure created in the combustion chamber.
It make higher compression/préssure cylinder
The spark needs to be stronger inside then a lower compression engine (stock YB or lower).
Anyway, 0.5mm now and pushing strong to 1.9bar.
I'm going to test tomorrow up to 2.2bar, see if 0.5 is still good enough.
Old Nov 3, 2015 | 12:17 AM
  #46
Mark Shead's Avatar
Mark Shead
If you are happy with what he says that is all that counts.
I run a bigger gap than that in Rods but then his coil system was spec' correctly to start with for what we where using it for.
Mark
Old Nov 3, 2015 | 08:05 AM
  #47
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
4 large Coils backed up with a CDI unit which is run at 16v from an Accuvolt system. Have run 2.9 bar with no probs & will be around 3.5bar on new engine.
Don't have a recent pic.
Old Nov 3, 2015 | 09:08 AM
  #48
SHaDoWLanDZ
Boost = life
Nice work
Old Nov 3, 2015 | 07:14 PM
  #49
smiley's Avatar
smiley
Glad you got sorted mate
Shaunc
Shows & Track Days
17
Sep 23, 2015 10:35 PM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
Flatlinedan
Sep 18, 2015 12:41 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
