Panel filter experts ???
Old Jun 25, 2015 | 06:14 PM
STeve's Avatar
Super Moderator
Default Panel filter experts ???
Whats the best free flowing panel filter on the market as I find k&n ones get blocked quite quick with stuff in the v grooves any better ?, dont want induction kits as its a NA car and they sound gay
Old Jun 25, 2015 | 06:58 PM
RichieST's Avatar
RichieST
Surely the quicker they get clogged, the better they are doing their job? If a certain type of filter stays cleaner longer, then surely it is passing the muck through it...
Old Jun 25, 2015 | 07:11 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
K&n and piper cross are the only panel filters I would use, and as said they clogg for a reason as there not letting too much past, do you use the oil cleaner?
Old Jun 26, 2015 | 05:43 AM
STeve's Avatar
Super Moderator
I know what you mean guys as I swore by k&n for many years but on my focus it seams to clog up way too much and yes I know its doing its job but opening up the airbox every few weeks is a pain it arse big time to brush the grooves clear, induction kits on NA cars is nearly all about noise and looks plus im too old for that bollocks, so im leaning towards pipercross as they mention the problem I am having with k&ns in their advert so lets see what £35 brings
Old Jun 26, 2015 | 08:01 AM
Bailes1992's Avatar
Bailes1992
A standard clean paper element is the way to go on a fairly standard car.
That filter much better and have far more surface area.
I've never had any good results from a panel filter.
Old Jun 26, 2015 | 12:54 PM
STeve's Avatar
Super Moderator
I have bit the bullet now and bought pipercross so will see if it pans out better than the k&n on the plus side I sold the k&n for £25 = result
Old Jun 26, 2015 | 04:35 PM
stevieturbo's Avatar
stevieturbo
C**t
Yep, OEM and change often if there are concerns
Old Jun 27, 2015 | 08:20 AM
tkracing's Avatar
tkracing
can u not airline clean it, takes two tics,no brushing needed?
Old Jun 27, 2015 | 09:20 AM
STeve's Avatar
Super Moderator
due to having a very free flowing exhaust I needed a decent fast flowing filter which is what made me go away from paper, but I will give the pipercross a go and see how its pans out in comparison to the k&n, as for the airline yeah of course but evey few weeks was getting tedious
Old Jun 27, 2015 | 10:19 AM
RichieST's Avatar
RichieST
An airline will fuck a panel filter as it will blow holes in the foam. To clean it use a soft brush and proper panel filter cleaning solution.
Old Jun 27, 2015 | 12:00 PM
stevieturbo
C**t
Originally Posted by 1-PD
due to have a very free flowing exhaust I needed a decent fast flowing filter which is what made me go away from paper, but I will give the pipercross a go and see how its pans out in comparison to the k&n, as for the airline yeah of course but every few weeks was getting tedious
Have you tested the OEM setup to see if it poses any restriction ?
Most modern cars flow very well, over and above what the engine needs, plus you get the added bonus of proper cold air feeds.
Old Jun 27, 2015 | 01:20 PM
STeve's Avatar
Super Moderator
yeah it was dyno'd not too long ago after fitting the decat and k&n and it had a tweek on the ecu too so all was as it should be Im using the OE filter box with a 2nd cold air intake so it was set up for this by the tuner and runs like a dream
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
