Fiesta Turbo-No spark
Picked up a Fiesta turbo today that's been stood for 8 years.
Put a new battery on it, fresh fuel & checked oil etc.
Turns over fine & fuel pump is priming but no spark. I've checked wiring plugs around the coil pack, checked fuses & all seems good.
I've never had any issues like this with a fiesta before so not sure if there's anything obvious I should be checking?
I also took the plugs out & gave them a clean.
I'm not great when it comes to electrical issues, I'm also inpatient so any help would be good
It Wasnt Me!
I had issues where mine would trigger the pump but wouldnt trigger the edis to fire the coils, try'd it with a jump and it turned over that bit faster and worked, so new battery...may be worth a try
So I've replaced the edis, coil pack & crank sensor but still no spark.
Can you bypass these like the escorts?
I mean like a live from the battery to the coil trick on the mfi's ?
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
