Testing Phase Sensors
Old Apr 2, 2005 | 10:54 AM
Ryan's Avatar
Ryan
Default Testing Phase Sensors
Is there any other way other than the Resistance test and the AC voltage test.
Basically we've tried 2 phase sensors, both give a resistance reading of around 580ohms.
But AV voltage is only like .2v instead of 1.5-2v.
We have done these test with 2 wires directly off the phase plug to eliminate and other issues.
Any advise?
Old Apr 2, 2005 | 11:14 AM
Stu @ M Developments's Avatar
PassionFords Creator
Need to use a scope, but the gap can vary the voltage, and a worn distributor shaft will bollox the signal totally.
Old Apr 2, 2005 | 12:45 PM
Ryan's Avatar
Ryan
gapped to 0.25mm
havent got a scope
Anyway to check for a worn shaft? Is it a case of just removing it?
Old Apr 2, 2005 | 12:59 PM
Set it at 0.3mm and if the shaft moves side to side, its fooked, simple as that
Old Apr 2, 2005 | 02:42 PM
Ryan's Avatar
Ryan
shaft moves like a nats cock amount of movement
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
