KA Rear Beam
My Missus KA rear beam is knocking about, there's a bit of a wheel bearing drone and the brake drums are squealing a bit. ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
My plan is to buy a second hand beam and refurb it then simply swap the rear axles over.
I was gong to fit powerflex bushes and axle spacers while I was at it.
Does anyone know of any differences in KA beams or will any one fit?
My Missus has a Non-ABS model. Would there be any issues fitting an ABS beam? I would personally assume the only difference being the brakes themselves.
I also noticed there is two different sizes on the trailing arm bushes. Will either size bolt up to the car okay or do I need to ensure the new beam has the same size bushes?
Cheers, Bailes.
Cheers, Bailes.
The only differences that I know of are the early beams pre '99 ish have a different suspension joint which some call a fork joint.
Other than that I beleive they are all the same from 99 on and don't know of any differences with the main beam bushes.
Hope that helps
Hope that helps
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
