4x4 diff help
Old Dec 24, 2014 | 10:53 AM
COLEYST200's Avatar
COLEYST200
Default 4x4 diff help
Hi lads I'm putting a skyline in my focos and I could do with getting the diffs as close to each uver as pos / the rashiows crown and pins as a skyline diffs are 100% the same so no drag when in 4x4 . Any help would be fab
Old Dec 24, 2014 | 01:58 PM
Caddyshack's Avatar
Caddyshack
I do not fully understand what you are sking for but most people use the Supra diff from a non turbo supra (3.9). If you are taling about the Skyline gearbox then have a search on the recent threads. I thinnk with this setup you can use the std front diff.
I know with an after market box I need 3.9 drop gears in the MT75 to work.
I hope this helps.
MK motorsport make the supra diff fitting kit and Bara motorsport can rebuild the diffs.
I hope this helps.
Old Dec 24, 2014 | 03:54 PM
COLEYST200's Avatar
COLEYST200
Thanks for your input mate wot is a ford mt75 gearbox has a visgos witch will help with the mis match I think the ford box runs at about 60/40 split but I'm told today at a place that dose skylines that there 50/50 split . and if I run 50/50 spilt on the track it could weld the clutch in the transfer box as the diffs could be working against each uver . But they did say if I run it like 70/30 and run a oil cooler it should be ok
Old Dec 24, 2014 | 07:13 PM
markk's Avatar
markk
The diffs must match front and rear within 2 decimal places ideally.
You would get away with a slight variation but not much.
The ford system is nothing like the skyline system, do not mix up torque split with drive split.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
