Engine oil additives
Old Dec 21, 2014 | 07:40 AM
3i Jim's Avatar
3i Jim
10 Year Member
Default Engine oil additives
Just wondering if there are any good engine oil additives out there for a modern diesel? Something that gives the engine protection on cold start.
Old Dec 21, 2014 | 07:46 AM
Bailes1992's Avatar
Bailes1992
What engine is it?
My Mondeo is supposed to use a 5w30 Ford Spec oil. During winter I use a 0w30 A5/B5 spec oil for improved flow rate when cold.
I think engine oil additives are a waste of time these days. Things don't sludge up like they used to with mineral oils years ago.
Just pick the right viscosity, use a good quality oil and replace it regularly (I change mine every 6,000miles or 6 months).
A bit of mechanical sympathy won't go amiss too. I try to give my car a minute or two idling when starting from cold to ensure oil is where it needs to be before loading the engine up. I'm pretty gentle on it until the coolant has been at 90° for a good few miles.
Old Dec 21, 2014 | 07:50 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
I use Slick 50, have for years. Maybe it's force of habit but I'd rather use than not. I change the oil every 3 months as well, again, that's just the way I like to do things. I also let the car run for at least two minutes from cold so all the oil ways, cams etc are fully lubed before putting the engine under any load.
Old Dec 21, 2014 | 08:11 AM
3i Jim's Avatar
3i Jim
10 Year Member
Originally Posted by Bailes1992
What engine is it?
It's a mondeo ST tdci. I had the clutch changed last week and I got the oil changed whilst it was at the garage. The oil they used is shit (noisy when cold and the turbo whistles slightly) so I'm going to change it on Tuesday. I'll bare in mind what you've said.
Old Dec 21, 2014 | 08:58 AM
Bailes1992's Avatar
Bailes1992
Get a 0w30 A5/B5 oil if you want a little extra protection. The oil will flow quicker when cold and provide more protection.
SmudgerByName
52
Jul 28, 2016 06:14 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
