towing weights
yup... I looked up a transit... limit is abotu a ton!
My point was I cant believe how little a connect can tow..
It also doesnt seem to matter as people tow all sorts to race meets and trackdays.,.. with escorts/cavs/astras!!!
Alex
Alex
Alex
Alex
have a look at t he gross train weight on your chassis plate , which is what the ministry use for determining the complete weight of the towing and the towed , your right about the overun braked trailers are always more than unbraked ( usually about 700ish kgs for unbraked ) but , if your cars loaded up all seats , boot etc , then the gross train weight applies , just beware thats all !!
from a gov web site
"There are only two legal requirements for weights and loads: One is that you must not exceed the Gross Train Weight (GTW) that is shown on the manufacturer's ID plate under the bonnet, and the other is that you mustn't exceed the trailer's 'Maximum Gross Weight'."
There is a third requirement:
If your Gross Train Weight exceeds 3500 kg you need a tacho.
I'm not sure if you might still need an Operator's Licence if it isn't "For Hire Or Reward".
The Knife,
no you dont , tachos are a thing on there own , can be on vehicle less than 3500kgs , all dependant on use i.e hire/ reward over 16 seats can have tacho , generally its for over 7500kgs on DESIGN GROSS WEIGHT only for hire/reward and not taxation of PLG or RECOVERY
i know a little bit about weights from a company i used to manage a few years ago , and it was very critical we stayed within the law
and operators applies separately all again
My experience is entirely with commercial operations so I don't know if there is an exemption for hauling your own stuff about, but anyone carrying goods over 3500kg needs a tacho. Our advice to anyone buying a towbar for a van plated at 3500kg is to have a tacho fitted. One customer refused and was caught on the A9 (Transit and Trailer) with a train weight of 6.9 tonnes - the van was impounded.
The full blurb is on:
http://www.vosa.gov.uk/vosa/privatehgvpsvowners/tachographsanddrivershours/ecdrivers'hoursandtachographrulesforgoodsvehiclesf aq.htm#P39_2031
But this is the important bit:
3.5 TONNE WEIGHT CRITERION [See Section 4 of GV262]
FAQ.2) What does "Maximum Permissible Weight" mean?
The EC drivers hours and tachograph rules apply to vehicles used for the carriage of goods, where the maximum permissible weight of the vehicle, including any trailer, exceeds 3.5 tonnes. Maximum "permissible" weight refers to the maximum carrying "capacity" of the vehicle, not the "actual" weight of the vehicle at the time in question. This means that the rules would apply whether or not the vehicle is laden, provided it is being used for an operation which is in scope of the rules [see Section 22 of GV262 for details on exemptions].
The rules are not confined to goods vehicles and can apply, for example, to a dual purpose (4x4) vehicle towing a trailer for commercial purposes.
Based upon earlier Court cases, the maximum permissible weight is calculated to be the lesser of:
The maximum permissible gross weight of the towing vehicle plus the maximum permissible gross weight of the trailer, or;
The maximum permissible towing (train) weight of the towing vehicle.
wowk
30-03-2021 07:49 PM
Cos500
16-09-2015 09:50 PM
