RS 500 engine....
Old Mar 31, 2005 | 06:03 PM
JimRS's Avatar
JimRS
Default RS 500 engine....
Hi guys, Heard about the RS500 engine is a bit different compared to the other Cosworths. Whats the other differences apart from the extra 4 injectors?
Thinking of building one!
Old Mar 31, 2005 | 06:16 PM
gus's Avatar
gus
also is the bell housing different to a normal t5?
Old Mar 31, 2005 | 06:17 PM
Rhys's Avatar
Rhys
Block is different, Turbo, Someone said Head too but im not sure on that
Old Mar 31, 2005 | 06:18 PM
Boost Junky's Avatar
Boost Junky
Yup and Heads different.. and the sump..
Old Mar 31, 2005 | 06:19 PM
Oranoco's Avatar
Oranoco
Block is different and it uses a T4 turbo and an 8 injector setup. Intercooler is the size of a small house as well. After that though I don't know
Old Mar 31, 2005 | 06:20 PM
JimRS's Avatar
JimRS
some1 said to me it can get an instant 500bhp by a modification or something?
Old Mar 31, 2005 | 06:24 PM
Boost Junky
I wouldn`t say instant.. but you have all the fundamentals already there for it.
Old Mar 31, 2005 | 06:26 PM
Karting's Avatar
Karting
everything is different, block, head, water galleries, oil galleries, i don't want to give to much information..........
Old Mar 31, 2005 | 06:30 PM
gus's Avatar
gus
what about bell housing?
kik1.6se's Avatar
kik1.6se
I read the early YB engines based on the Pinto block and they selected out the best casting to use. I think the RS500 was the first YB which had the cosworths own block.
Kirk
Old Mar 31, 2005 | 06:32 PM
Toe Knee's Avatar
Toe Knee
To get 400+ bhp you need to get the extra 4injectors wired up cos their not from memory and the ECU played about with?!
But as said the block was vert different including smaller core plugs which makes them easy to identify!!! The throttle body was bigger etc. Dont think the head was too different but could be wrong on that!!!
But pretty much easy to get big power out of them hence ppl used to go the 8injector route a while back!
Old Mar 31, 2005 | 06:33 PM
Karting's Avatar
Karting
different block all together..................
Old Mar 31, 2005 | 06:36 PM
big_wig_074's Avatar
big_wig_074
bloody expensive to buy the 8 inj setup though,hope you got some moolah!
ImaRacing 700's Avatar
ImaRacing 700
Head is the same as the 2wd..block is much thicker with an 800bhp flex rating,bigger throttle body,8 inj plenum,intercooler,ecu is a std LEVEL 1 that needs to be converted to run 8 by collins or pectel,T4 turbo...not much else is there!!
Old Mar 31, 2005 | 06:37 PM
SPADGE's Avatar
SPADGE
Old Mar 31, 2005 | 06:38 PM
ImaRacing 700
You can get 500bhp by modding the ECU and fitting 8 greens and some head porting and changing cams and map sensor YES
Boost Junky
Heads are not the same... minor differences to the inlet side
Old Mar 31, 2005 | 06:40 PM
Karting's Avatar
Karting
WRONG......head is different........
Old Mar 31, 2005 | 06:41 PM
SPADGE's Avatar
SPADGE
In what way different? Please don't say the 2 dowels for locating the inlet manifold
Karting's Avatar
Karting
sssssshhhhhhh. boost junky??
Old Mar 31, 2005 | 06:44 PM
ImaRacing 700
Exactly Spadge..... RS500 owners need to feel they are special though so ok...give you that
Boost Junky
Old Mar 31, 2005 | 06:47 PM
SPADGE's Avatar
SPADGE
Don't they just
Fact is an RS500 engine is a mile away from being a 500 hp motor and the engine would need modifying in virtualy every dept to make 500 hp reasonably reliably!
Old Mar 31, 2005 | 06:50 PM
Karting's Avatar
Karting
RS500's are special, & if I tell you everything, you would know why they are special.
Don't they just
WRONG.............................................
Old Mar 31, 2005 | 06:51 PM
chester's Avatar
chester
The head of a RS500 is exactly the same casting as any late 2wd head with a 3 bolt thermostat mount on the front (I have one in my shed for spares). The only difference is two holes in the mating face where the plenum attaches for two small dowels to sit, and the fact that the inlet tracts were machined out very slightly at the entry point.
The pistons, rods, crank etc are all standard 2wd items only the oil pump is different which was the prototype version of the 4x4 pump. Same goes with the thermostat housing this was an early development of the 4x4 one
The only special part of an RS500 engine is the block and all its bolt ons - technically the 4x4 internals are superior to the RS500 as they have a better piston design reducing piston slap and oil spray arrangement.
All fact not hearsay
Old Mar 31, 2005 | 06:53 PM
markcoznottz's Avatar
markcoznottz
RS500 head was ported on the inlet side. The block was a stiffened casting, with as mentioned smaller core plugs. T4 turbo, enlarged intercooler, eight injectors.
Old Mar 31, 2005 | 06:56 PM
Karting's Avatar
Karting
Yes the pistons are not off set any more???
What about the new 202 block????
daz1968's Avatar
daz1968
I was lead to believe the block is special, with an uprated oil pump and spray bar and bigger water pump with different thermostat housing, , the pistons are also different to suit block and the head casting was just the 3 bolt one which was used on 2wd saff, with different exhaust valves, and then just the plenum and turbo, but maybe wrong as been a long time since I looked into it.
Old Mar 31, 2005 | 07:01 PM
SPADGE's Avatar
SPADGE
Don't they just
Lol so what makes you more knowledgable than i?
Have you had a 500hp engine???
Old Mar 31, 2005 | 07:03 PM
Karting's Avatar
Karting
chester The head of a RS500 is exactly the same casting as any late 2wd head with a 3 bolt thermostat mount on the front (I have one in my shed for spares). i will swap a2wd head with you put your money where your mo..h
Old Mar 31, 2005 | 07:05 PM
SPADGE's Avatar
SPADGE
So 'karting' in your expert opinion tell me exactly what you would need to do to make a stock rs500 make 500hp reliably please!
Old Mar 31, 2005 | 07:12 PM
chester's Avatar
chester
Karting,
having dismantled every single type of cosworth engine my information is first hand fact, not read from books and the internet.
How many engines have you stripped to provide your information.
You can buy this head from me if you like, it is complete but one cylinder is completely mashed where no 3 piston let go - make me an offer and put your money where your mouth is.
I shall take some photos if you like
Old Mar 31, 2005 | 07:13 PM
Karting's Avatar
Karting
i going past milton keynes I am going past Milton Keynes, would you like to swap heads??
So 'karting' in your expert opinion tell me exactly what you would need to do to make a stock rs500 make 500hp reliably please! I think Stuart would be the best person to answer this question.
Old Mar 31, 2005 | 07:14 PM
Karting's Avatar
Karting
what head no is the head????????????
Old Mar 31, 2005 | 07:15 PM
SPADGE's Avatar
SPADGE
So you don't fookin know lol
I am in Milton Keynes not chester and i have no wish to give you head thanks!
Old Mar 31, 2005 | 07:16 PM
JimRS's Avatar
JimRS
Where can I buy 500 engine parts from?
Old Mar 31, 2005 | 07:18 PM
big_wig_074
ebay?here?cosworth themselves?LONG list!
SPADGE's Avatar
SPADGE
What parts do you want?
There is no need to buy a 500 block as the 200/4x4 one is better
There is no need to buy a 500 head as a 4x4 one is better
Which parts do you think you need
Old Mar 31, 2005 | 07:19 PM
JimRS's Avatar
JimRS
im thinkin of bidding on this 200 block what you think?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MEWA:IT
Toe Knee's Avatar
Toe Knee
oh and click 'quote' when u reply Karting it makes ur posts easier to read
Fact is u cant just get 500bhp from an out the box 500 engine!!!!!!!!!! which i think is spadges point
