RS 500 engine....
#41
Originally Posted by JimRS
im thinkin of bidding on this 200 block what you think?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MEWA:IT
#42
Where can I buy 500 engine parts from?
There is no need to buy a 500 block as the 200/4x4 one is better
There is no need to buy a 500 head as a 4x4 one is better
Which parts do you think you need
#43
#46
#47
In fact if you really want a cossie lump to play with this one is a much better buy
http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MESE:IT
#50
Re: RS 500 engine....
Thinking of building one!
#51
Karting
I do not want to get on a band wagon of slating your knowledge but you are doing yourself no favours here, the 202 block is just a late 2 litre pinto block for a 1992 transit van.
All cosworth blocks have the same physical dimensions as any 2 litre pinto - you could take a 2 litre pinto block from any mid 80s on, Ford vehicle and install all cosworth internals and strap on all the RS500 bolt ons and it would run ok at normal operating conditions.
Owning a mint RS500 and knowing in first hand detail the construction of them are two different things.
I only ever get involved in discussions when I know first hand the information I am providing is accurate.
#53
Originally Posted by Karting
chester....Yesterday number stamped up or down, information for you has been stopped.
#55
Rs500 DataBase Editor
Originally Posted by Rs Gus
would cost 8-10k at a tuner to get 500bhp fook it ill buy a std rs500 lump and have 500bhp
#56
RS500 ownership is not a secret society, the info is readily available you do not hold the rights to it - why get stroppy just because you do not know everything about them and someone proves you wrong on a few points
Listen and Learn, then quote facts not hearsay
#57
Hi guys, Heard about the RS500 engine is a bit different compared to the other Cosworths. Whats the other differences apart from the extra 4 injectors?
RS-500 inlet manifold/plenium assembly with 8 x green injectors fitted,
70mm throtle body, TPS, ISCV, dual fuel rails, regulator etc.......Good for 550/560 BHP on the correct spec engine
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
