Starter motor help? Making noise i think.
±§~Quadzackular~§±
Hello,
So I've took the starter motor off my Citroen Berlingo 1.9 and all the teeth look fine but sometimes its won't start and makes a noise that i thought was the starter not engaging.
Could there be something in the starter that makes the noise?
Cheers.
Cheers.
±§~Quadzackular~§±
Didn't see a dowel, just 3 bolts holding it in place.
Also never saw any diesel but think there is a oil leak somewhere thats very slow above it. Ill take it apart and have a look. Should i use brake cleaner or just a wet rag?
Cheers.
Cheers.
±§~Quadzackular~§±
Cleaned it last night and its back on now, started first time and did so for another 4 times.
Didn't know if i should of greased it though so it moves in and out better.
Just see if it happens again i guess.
Cheers.
Cheers.
cossie09
10-09-2015 06:56 PM
