removing primer overspray? best way without using abrasive products?
![Cool](https://passionford.com/forum/images/icons/icon6.gif)
whats the besy way to get rid of this primer overspray?? ive tried some soap and water (as primer is porous) with a medium bristle brush and it wont come off, i dont want to use anything too hard and ruin stuff, if you scrape it with your fingernail it will come off but i would be there for years doing it. i dont want to use anything too potent or abrasive. got a few days off work to try and get rid of it if i can. ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![](http://i61.photobucket.com/albums/h48/robpace/overspray_zpsce87fa7a.jpg)
![Name: overspray_zps0e5656f7.jpg
Size: 48.7 KB](https://passionford.com/forum/attachments/general-car-related-discussion/46408d1501347358-removing-primer-overspray-best-way-without-using-abrasive-products-overspray_zps0e5656f7.jpg)
Not sure you'll find any easy way...other than painting or coating over it.
What sort of primer was it ? If cellulose you might get lucky and cellulose thinners maybe take it off ?
Use a claybar. That's what claybars were originally designed for.
It'll get all that off, but it will ruin a good claybar, so use an old one or one you're happy to ruin.
Claybar IS abrasive, but it's the most gently abrasive you'll get so shouldn't cause any issues.
You''ll need plenty of lube and a few hours set aside to tackle that, but it'll do that job.
In terms of lube, a a decent, slippery shampoo in a bucket of water will do that job as obviously you'll need lots and you don't need to be quite as careful as you do when claying your nice, shiny paintwork, but will need a lot of it.
Panel wipe is safer if your not confident enough to wipe over with thinners...
