Fuel pump drawing 16 volts?!
Today driving the cos home.
On idle the fuel pump starts buzzing hard and as I have my volt meter wired to it was spiking at around 16v?
It's part of a -6 aeroquip system.
Fuel cell -> lift pump facet -> swirl pot 1.5litre -> 044 -> sytec filter -> rail -> regulator -> return to swirl pot
Any ideas?
Pump is 2 years old done maybe 1000 miles max
Cheers Billy
Any ideas?
Cheers Billy
Is that volts gauge picking up voltage from entire charging system? If so the regulator on alternator could have gone? Have u checked charge voltage at the battery? If 16v at battery then I'd say alternator regulator
16V I am surprised it hasn't cooked the battery! I had an old rover where I had to run the lights the fans and everything to try and keep the voltage at 14.4 or it boiled the battery lol
Any ideas?
Cheers Billy
Any ideas?
Cheers Billy
A pump cannot draw 16v unless something in the system is providing it with 16v.
ie check your alternator.
And overcharging can cook other parts too, like the battery. Has it been smelling bad or leaking acid lately ?
The pump itself will be perfectly happy and safe at 16v though
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
